fireblade 2005 pops 4th gear
Discussion in 'Maintenance' started by adamos, Mar 21, 2014.
  1. martinowen
    Nope they won't fit, the shaft size is slightly bigger on the 06/07 so you would have to replace the whole clutch basket etc
  2. adamos
    adamos Active Member
    do you konow what size should be on teh 04-05 ?
  3. daz1
    daz1 Active Member
    theres a 6/7 grarbox £200 and a complete 6/7 clutch £75 from same seller on ebay will try to find him if you buy both items it will fit
    #23 daz1, Mar 24, 2014
  4. daz1
    daz1 Active Member
  5. adamos
    I'm lucky too got gear box for 130 inc post
  6. daz1
    daz1 Active Member
    looks like we both got lucky then
  7. martinowen
    Nice one! Maybe I was just unlucky lol
  8. daz1
    daz1 Active Member
    well gearbox as arrived i just need to get my ass into gear and fit it [no pun intended] lol Picture 003.jpg Picture 004.jpg Picture 005.jpg
  9. adamos
    Yesterday my gear box completly gone also make small hole in engine case. I'm stupid idiot :mad:
    Any body know how or who can weld engine case?
  10. Mike07
    Mike07 Active Member
    Can you post a picture of the damage to the case?
    Mike.
  11. martinowen
    What else has it damaged with it?
  12. adamos
  13. adamos
    I can't see more damaged. Tomorrow I will try looking in side. I belived it is no more damaged :confused:
  14. martinowen
    Hopefully the clutch basket etc is ok
  15. Mike07
    Well if the case is usable apart from that damage and depending what you want cosmetically, it could be a reasonably easy fix. Yes you can weld it but I would consider a bodge fix (or a second hand case) getting some 3mm aluminium sheet and using an adhesive. I have seen this done before with good long lasting results, drilling it and putting a bolt in if the clearance is sufficient is another option the list of remedy's is endless, only your imagination will number them.
    Good Luck, Mike.
  16. Dave
    Dave Member
    Hi Adamos, nasty little punch hole that, as a welding company owner i must say that we do lots of repairs on engine casings, we have a fireblade crankcase in at the moment awaiting repair. To repair the casing properly you would have to strip the motor, so best fix as one of the other guys has already mentioned is to either patch over it or JB Weld over it, whichever you do make sure it is spotless before applying JB weld or adhesive for patch. Use acetone or brake cleaner.
  17. scooby
    scooby Elite Member
    i'd be more worried what other damage it has done inside,but you wont know that till you strip it apart and have a good look.
  18. adamos
    I have problem unscrew nut any one know what size it is? sugestions how moved plssss
    #38 adamos, Apr 13, 2014
  19. Dave
    Dave Member
    Evening,do believe its 32mm, having recently removed ours this is what we did : engaged a gear locked the engine sprocket with a sprocket clamp and undid nut, was seriously tight don't forget to lift the little locking tab which is part of the nut. Fortunately for us we are a fabricating company and able to make one off tools ie sprocket clamp, but you can improvise and lock the sprocket by other means.
  20. adamos
    Got it
