Fireblade HM Plus Quickshifter 2001 - 2020
Discussion in 'Parts, Accessories & Clothing' started by brg1000, Sep 2, 2020.
  1. brg1000
    brg1000 Active Member
    Just as the title says HM plus generation 2 Quickshifter in excellent working order and guaranteed 3 months.
    The HM shifter is an ignition based shifter and so you will need to plug the coil loom into the coil stacks. It plugs in line with the factory loom and once fitted the HM allows sensitivity adjustment as well as kill times. The shift module can be configured to operate push, pull or both. It wont act as an autoblipper so you will only be able to use it to shift 1 - 2 - 3 - 4 - 5 - 6.
    The HM plus is a great shifter and although you will hear all sorts of rubbish about shifters these do not break gearboxes any more than ham fisted shifts will. Properly setup these are actually easier on gearboxes than traditional clutched or clutchless shifts. One fitted you can enjoy smooth seamless shifts without getting off the throttle. If you have never used a quickshifter you will wonder what life was like before you tried it. They are simply great fun.
    This shifter can be fitted to any CBR1000/900 Fireblade from 2001, 929, 954 and 1000RR. It will come complete with instructions, link rod and of course the shifter with the Honda loom, The honda loom is incidentally also used on any 4 Cyl Suzuki again from 2000 onwards.
    Pictures available on request.
    Price - £199.
    Post - UK - £7
    - Europe £12.
    Barry 07921 849 076
  2. Naz
    Naz Active Member
    @ignatius was you after one of these
  3. ignatius
    ignatius Active Member
    Thanks @Naz , still contemplating to have a quickshifter.
  4. Stuish
    Stuish Senior Member
    Do it, you won't regret it. Can vouch for @brg1000 and his quickshifter posts, it's where I got mine from :) It's the most grin inducing thing you can do to your bike!
  5. ignatius
    Thanks for the advice @Stuish , definitely wanted it as a must for blade. Will decide soon.
  6. brg1000
    Thanks mate. Appreciate the round of applause. your cheque is in the post
    • Funny Funny x 2
