Fitting ohlins damper and un-hooking stock damper
Discussion in 'General 1000RR Discussion' started by Andrew Williams, Oct 16, 2018.
  1. Andrew Williams
    Andrew Williams New Member
    Hi guys, after a bit of advice. Ive got 2009 model and Ive fitted the hrc front subframe and ohlins steering damper. I unhooked the original damper via taking the arm off the spline, can it be left in this configiration for track with out any problems?
    Ive attached an image, the arm will be comoletely unbolted 15397033663222884645957262447240.jpg
    Thanks in advance
  2. Lifeofriley
    Lifeofriley New Member
    I would remove that arm off the spline bud.
  3. Spygoat
    Spygoat Well-Known Member
    agreed
  4. Andrew Williams
    Yeah thats coming off buddy, will the damper be ok to be left on though disconnected?
  5. Andrew Williams
  6. Lifeofriley
    Yes mate it will be fine. Why not remove the hole unit and ignore the hesd light?
  7. Andrew Williams
    Yeah thats what id like to do really mate, the unit simple to remove?
  8. Lifeofriley
    Ah yes mate piece of piss. Removed mine recently but i run hrc loom and ecu so no issues with hiss or hesd.
  9. Andrew Williams
    Ok cool, that shit can come off tomorrow then with it unplugged and off it will juat throw a perminant light up on the dash is it? No chwmage in performance ect?
  10. Lifeofriley
    Im not to sure mate i would have Thought it would just throw a code but i did just read the older model would put it in limp mode! Doesnt seem tobe much info out there on it.
  11. Andrew Williams
    Maybe ill just take that arm off and run like that until i can get it mapped out. Its still plugged in that way so i assume it wont throw up a fault
  12. Spygoat
    Likely the bike will go into limp mode with it unplugged. Not sure anyone makes an eliminator for the unit.
  13. roboticus
    roboticus Active Member
    think u can turn it off with a ecu tune
  14. Andrew Williams
    Has anyone ran there bike on track with the original damper disconnected but it still plugged in?
  15. Spygoat
    I haven't. I run mine with the HESD and haven't had any issues with it.
  16. Lifeofriley
    I've had some nasty head shakes so bored it off! Aggresive gearing doesn't help!
  17. Andrew Williams
    Ive gone ohlins on mine now so dont need the stock damper on there no more
  18. Spygoat
    I'm running stock gearing on my SP, eventually I may add an Ohlins to the system. At that time I'd likely have the HESD programmed out.
  19. Andrew Williams
    Yeah i think best option is get it mapped out and then just remove unit all together
