Foggy mask ?
Discussion in 'Racing & Bike Sport' started by Scott, Feb 1, 2015.
  1. Scott
    Scott Active Member
    Do u don't u , thsts it really
  2. scooby
    scooby Elite Member
  3. thefirebloke
    thefirebloke Elite Member
    Can't beat a bit of Fairy Liquid! :)
  4. Scott
    Scott Active Member
    Up ur nose ?
  5. thefirebloke
    If you like, but I'd rather put it on the inside of my visor!
  6. Barstewardsquad
    Noooooooo!!!!! Not fairy liquid, it has salts in it that don't do your visor any good.
    My Shark lid came with some coating that is good, but pinlock gets my vote.
  7. wedgiewolves#223
    wedgiewolves#223 God Like
    Foggy mask I think to restrictive moves about or end up sucking it in when racing . Fairy liquid is sworn by i the race paddock . Pin lock has my vote though after trying in my helmets
  8. scooby
    scooby Elite Member
    problem with pin locks I find is that the seam of it can be in your line of vision which is a bit off putting.
    fairy liquid does the job,as does (cant remember his name,uncle bob?) visor demister works well aswell.
  9. GappySmeg
    GappySmeg Well-Known Member
  10. Phil blade #57
    Pin lock gets my vote
  11. Scott
    Scott Active Member
    Won't bother with the foggy now saves me £15. My pin lock didn't always work mSyb it's not seated right
  12. thefirebloke
    Totally agree Scott, I put a Pinlock in a brand new visor at the beginning of last and it steamed up round the edges! Ended up using both Pinlock and Fairy! Also agree with Scooby, it does restrict your peripheral vision slightly.
  13. Mr OCD
    Mr OCD Well-Known Member
    If it's steaming round the edge then it's not adjusted right chaps ... The two mounts are elongated and turn to tighten pinlock against visor creating an air tight seal...
  14. Mad Matt
    I would sooner have a Rossi mask, won more;)
  15. thefirebloke
    Think I didn't explain properly....... it was the part of the visor outside of the Pinlock that steamed up. Although I could see clearly through the Pinlock, extreme peripheral was clouded and restricted total vision. :)
  16. thefirebloke
    Also any kind of "mask" has me gasping for breath as it restricts oxygen slightly and defeating the object!
