Forks
Discussion in 'Maintenance' started by Chris Hunter, Apr 22, 2019.
  1. Chris Hunter
    Chris Hunter Active Member
    Folks, mamaged to get forks off, when they go back on, is there a way of torquing all the pinch bolts back up without taking the nose cone off? They were a nightmare just to get to with an allen key!
  2. Kilr'b
    Kilr'b Active Member
    Just did mine on an 08. Take your time and u should be able to manage without taking the upper off. Turning the steering (if on a triple tree stand) and rotating the clip ons on the fork tubes should give you enough wiggle room to reach both sides with a ratchet and allen bit.
  3. Chris Hunter
    Cheers buddy. I only just managed to get a standard Allen key in with the help of a bit of swearing. I've just ordered a stubby set of keys that should be perfect for it
  4. Kilr'b
    Small ratchet is actually be easier as you don't constantly have to reposition;)
  5. Jez
    Jez Senior Member
    I have a 1/4" ratchet spanner that I put in a 6mm bit, It is still a pain but manageable. I don't over tighten bolts so the short ratchet spanner is fine.
