Front Brake Caliper
Discussion in 'Maintenance' started by pete954, Jan 10, 2016.
  1. pete954
    pete954 Active Member
    Has anyone seen or heard of this happening before. While installing the left front caliper and pinching up the top pad retaining pin, there was a sudden ease in screwing it in resulting in a cracked caliper. You can jus barely see it in the photo Don't suppose anyone has a spare lying around, cheers uploadfromtaptalk1452419511647.jpg uploadfromtaptalk1452419527566.jpg
  2. raphael
    raphael Elite Member
    Think there was a post by daz selling a pair? Might be worth a search?
  3. jc6830
    jc6830 Active Member
    Try Mark.. yorkshiregooner, he'll have one. 07752369099
  4. sps170373
    Looks like you might have over tightened it, were you using a torque wrench in it?
  5. sps170373
    Looks like you might have over tightened it, were you using a torque wrench on it?
  6. pete954
    All I did was "pinch" it up with a1/4 drive ratchet, just to the point where the thread locks, then "ping" . I guess shit happens as they used say [emoji1] [emoji1] oh and the torque wrench was in hand ready for final tweak
  7. Slick
    Slick Elite Member
    The torque on them is pretty low, I would double check the pin against OEM.
    If is is longer it will potentially touch the other side and when tightened effectively pull the calliper apart.
  8. wedgiewolves#223
    wedgiewolves#223 God Like
    I have caliper/calipers if needed text 07498987113
  9. clanadam
    clanadam Active Member
    Don't spose you still have the Front RHS caliper Wedgie? Mine is a 2009 blade and I've cracked it :-(
