front brake pads
Discussion in 'Mods, Upgrades, Accessories and Products' started by rebel, Apr 6, 2015.
  1. rebel
    rebel Active Member
    Need a bit of advice basically the front brake is shit its a abs model but I don't think its a abs problem I bought the bike end of last summer didn't seem that brilliant at the time any way parked it up for the winter took it out yesterday for the first ride of the year and again today the front brake feels a bit spongy but there's no bite there whatsoever it feels like your not going to stop its a 10 plate 3000 miles any way I'm going to order some new pads and see if that makes any difference iv been looking at SBS sintered or ebc or does anyone have any better recommendations
  2. Cbrjay
    Cbrjay Well-Known Member
    My 14 plates don't feel great, some times spongy some times ok.
    I've always used ebc, my mate put brembo in his blade and took them out due to juddering.
    I've got some hel brake lines to go on it, when was the brake fluid last changed?
    Might be worth changing fluid/check Pistons move freely
  3. Colonel_Klinck
    Colonel_Klinck New Member
    If it feels spongy first thing I'd do is change the fluid and bleed them properly.
  4. Cbrjay
    Once you bleed them leave a cable tie holding lever on over night so the air will raise up to master cylinder
  5. Ian E
    Ian E Active Member
    Never had a problem with standard Honda pads on 2008 / 2014 Non ABS and 2012 ABS. Maybe the pads are contaminated with oil or something? It would definitely be worth cleaning discs and replacing pads.
  6. Slick
    Slick Elite Member
    I think a check and good clean/bleed is in order.
    Like Ian said the OEM pads are very good, check them for contamination/glazing etc, clean the discs and bobbins too.
  7. scooby
    scooby Elite Member
    as above,bleed the system and nothing wrong with standard honda pads
  8. sinewave
    It's an ABS, so A, Bleeding is beyond most Home Mechanics and B they feel spongy anyway.
    It's worth doing however but will cost you a fair bit at the Stealers.
    If U bought from a Dealer it's a shame U didn't mention it straight away as a full ABS bleed aint cheap and would've been done FOC last year I'd have thought
  9. rebel
    rebel Active Member
    Thanks for the advice I'll strip them down and give them a good clean thinking about it I did spray the bike with acf50 before I laid it up for the winter so I could of got some on the discs and not cleaned it off
  10. stuart_g
    stuart_g Active Member
    I put SBS Street excel pads in my 2010 blade and they made a massive difference. I plan to put them in the 2012 as well.
  11. Mr OCD
    Mr OCD Well-Known Member
    The SBS RS pads are awesome !
  12. rebel
    rebel Active Member
    Are these alright for the road or are they more for the track
  13. Mr OCD
    Fine on road :)
  14. rebel
    rebel Active Member
    Just ordered a set
