Front calliper bolts
Discussion in 'Maintenance' started by bonjo, Dec 6, 2019.
  1. bonjo
    bonjo Active Member
    Decided to get new ones as the bike will be due for a tyre change + 16k service.
    The service manual says the OEM ones are ALOCbolts
    Thanks to eagle eyed members, I ordered a Ti set from pro bolt on discount.
    So I fitted them using red loctite and not copper grease and torqued to 40 Nm instead of 45
    I did notice some differences don’t know if they are important or not. Have emailed pro bolt for their feedback
    bolt head is smaller 12mm spanner as opposed to 14
    Bolt flange diameter is smaller by 1.5mm
    Bolt length under the flange is 2 mm shorter
    anyone else noticed these?
  2. raphael
    raphael Elite Member
    Have been using the same bolts as these for nearly 60k mate(one set) and not had one problem.
  3. sps170373
    the oem bolts from memory are 62mm long which by bolt lengths is an odd size
    most go for 60mm or 65mm which are standard bolt lengths
  4. bonjo
    bonjo Active Member
    Went for a test ride today, nothing collapsed
    Yes OEM are 62 and pro bolt 60 as you mention
    Having looked at the OEM, can see them stretch on the callipers. I think the latter would give first!
    Looking at mine, OEM have locking compound on them so low strength loctite is the order of the day.
    Rapha if I were doing it myself, would end up reusing them like you. I guess garages want to change them to cover themselves.
  5. bonjo
    bonjo Active Member
    Looks like a happy ending.
    Wrote to probolt about my findings.
    Their technical expert replied with explanations for the differences and put my mind at rest.
    BTW the slightly smaller flange diam fits & looks better as the OEM ones stick out a bit
  6. hitch
    hitch Elite Member
    What is there technical explanation out of interest? (I used those bolts as well)
  7. bonjo
    bonjo Active Member
    Here is extract from the email
    All of our products are test fitted and trialed on the bike in question before we list them on the website, even if sizes slightly differ to OEM we will always ensure the suitability and safety of a product specific to the bike.
    Our bolt designs differ slightly from OEM specs, however, unlike OEM we manufacture in high grades of materials - Stainless steel (316) and Titanium (Ti-6Al-4V) and as such we have reduced the head diameters & machined out the heads for maximum weight saving. But this will have no impact on the safety or performance of the brakes or calipers
