Front sprocket - gearbox shaft movement
Discussion in 'Maintenance' started by Gilesy, Jun 27, 2014.
  1. Gilesy
    Gilesy Elite Member
    Just changed the chain and sprockets for a 520 conversion. Noticed that when I removed the front sprocket cover (that I just modified - but more about that later), the front sprocket bolt was tight on the shaft, but the shaft has about 1mm of play back and fore.. should I be worried??
    Video posted in a few mins..
  2. Gilesy
    Gilesy Elite Member
    While I'm waiting an age for the video to upload to youtube, a pic of the front sprocket cover - cut a big hole in it so the sprocket shows through! God those 520 chains are thin, about 70% of the standard chain I had on.. hope its strong enough lol :eek:
  3. Gilesy
    Gilesy Elite Member
  4. Ian E
    Ian E Active Member
    Its normal - I had the same on my RR6 and my RR8.
  5. Gilesy
    Gilesy Elite Member
    Really.. I'm thinking that there is a bearing worn with that movement.. good to hear you've seen it before though.
  6. lambchops
    lambchops Elite Member
    Will have a tug on mine tomorrow for you... Oh dear that sounds so wrong!
  7. Gilesy
    Gilesy Elite Member
    another video:
  8. Gilesy
    Gilesy Elite Member
    haha just a shake of your sprocket will do LC haha :D
  9. kev.b
    kev.b Well-Known Member
    My 06 blade is the same . its fine .
  10. Stevie_d
    Stevie_d Senior Member
    Imagine it's so the sprocket can move ever so slightly to align itself with the chain and the back sprocket ?
  11. bandit_287
    bandit_287 Active Member
    What's the advantage of a 520 chain instead of a 530? Surely it'll be weaker and more likely to snap.
  12. Gilesy
    Gilesy Elite Member
    well I guess you could say its more likely to snap "if not looked after"..
    I'm no expert, nor racer, but racing bikes use 520 chains as they are thinner, lighter, so less mass to move therefore easier to spin up.
    I bought it because I wanted to try one really.. no other reason :)
  13. lambchops
    Finally remembered to have that tug for you :)
    Doesnt have any in out movement from what I can tell.. Does have a tiny bit of side to side as the sprocket moves on the spline a tad.
  14. Souleh
    Souleh Active Member
    My RR9 does move 1mm odd. Using 520 chain/sprockets
  15. bandit_287
    Can you post up if the 520 chain feels better or different to what you've had on previously? I'm curious as if it feels significantly better I might try one on my next chain/sprocket swap.
  16. Souleh
    Mines a race bike. For sure a 520 wont live aslong as a 530 or 525, ive had 3 fitted in a year and thats lubed every time the bike comes out.
    As said above though its less weight and because the chain rotates as such speed, that weight is magnified so it makes a worthwhile difference when all you care about is speed. Also most race gear is 520 so very easy to get sprockets and chains. Looks a bit better imo but its purely a performance thing.
    I bought the bike already with 520 (never ran anything else) so cant compare sorry
    Some random pics for the craic
  17. Gilesy
    Gilesy Elite Member
    well the only difference i can tell so far is that the rear wheel on the stand spins like there is no chain! with the bigger chain there was some resistance..
