front wheel noise .
Discussion in 'Maintenance' started by keithg1748, Jan 20, 2019.
  1. keithg1748
    keithg1748 Active Member
    hi im looking for a little help or any ideas , there was like a scraping or summat catching noise on my uncles bike when the front wheel was spinning , so stripped calipers cleaned and new seals etc , wheel bearings seem fine , but noise is still there you cant hear it at speed but when slowing up to junction but soon as you just slightly touch the brakes the noise goes away , so any ideas , thanks .
  2. slasherr
    slasherr Active Member
    My first thought would be brake pads lightly rubbing on the disks, this is quite common, especially as you suggest the noise dissapears when applying the front break.
    Another possibility is a brake hose moving against of the retaining clips.
  3. sps170373
    Check all the disc buttons are moving freely if not it’ll be as slasherr has said and the disc is rubbing the pads
  4. Kevin1
    Kevin1 Elite Member
    easy to miss the buttons on a brake service but they are very important. Just use a nut and bolt and a ratchet to wind each one round and round. Do not use any lubricant though.
    #4 Kevin1, Jan 20, 2019
  5. keithg1748
    will try that . thanks
  6. bazzashadow
    bazzashadow Elite Member
    I done this to my VTR
    I did use a lube but only a tiny bit and cleaned all round afterward
    some of them where seized
  7. bazzashadow
    look on youtube and it will show you how to do it
    bolt with two nuts on
    tighten nuts on bobbings and turn bolt carefully
  8. nigelrb
    This is all new to me because I come from the 'drum brake' era;)
    It seems you're saying the 'buttons' should be a tight fit but still able to rotate? (Hence the term 'floating discs' I guess)
    And your means of checking is to run an appropriately sized bolt and nut through the holes and then tighten and rotate the whole button?
    Edit just seen new post above re You Tube. Will check, cheers!!
  9. bazzashadow
    what are they called
    buttons or bobbing's
    I call them bobbing`s
  10. nigelrb
    • Useful Useful x 2
  11. keithg1748
    bobbings . me to ,
  12. bazzashadow
    I do it a bit different
    I use a bolt and two nuts (which can be nylock)
    I put the bolt through with one nut already wound on and then nip the bobbin between the two nuts,
    then I turn the bolt backwards and forwards:)
  13. Stuish
    Stuish Senior Member
    I had not even known that this was a thing you need to do! Thanks for this :)
    • Agree Agree x 2
  14. bazzashadow
    Like nigel has said
    That’s the reason it’s a floating disc
    And you can buy new bobbin’s
