Front Wheel Removal
Discussion in 'Maintenance' started by Rob, Apr 1, 2011.
  1. Rob
    Rob Administrator
    Hi Chaps,
    I need to take my wheels out to the tyre fitters. I have an Abba rear stand but no front stand. I have a normal car jack.
    Last year I used the jack and the Abba stand to do a fork conversion on a Street Triple and had no problems using both jack & Abba stand to get both wheels off the ground.
    Question: Can I achieve this on the Blade using the jack under the headers with the Abba stand on the or do I need to get a dedicated front stand? I have not looked under the fairing to check if there is a gap for the jack to sit onto the headers?
    Thanks in advance :)
  2. garyauk
    garyauk Active Member
    The front headers will take the strain, but that being said I wouldn't. You can buy a front stand so cheap nowadays
  3. zeepony
    zeepony Active Member
    +1 :)
  4. Rob
    Rob Administrator
    Ahh sod it, :no: on second thoughts I'm going to do the lazy option and let the fitters do it!! Thanks for the replies though
  5. zeepony
    Much better option - fitting is normally free? Take it to FWR...
  6. garyauk
    You could always get 3 mates around to hold up the bike for you.......This is what we had to do in France a couple of years back, as a friend of mine had a service and front tyre on his blade before the trip. When we got there we found that the front wheel was in the wrong way around!! This was a Honda main dealer.
  7. zeepony
    Hahaha - double hahaha for Honda main dealer fail!
    I also think you can pitch the bike at an angle on the side stand then lean it against something.. seen it done but would not try it on mine!
