Where are you guys running the loom? I've run it down the clutch side but still not 100% happy ... I like things to be right lol.
Run it behind the clock and under thd fairing stay. If you take the tank off you can run it along side the steering damper brackets and cable tie it to the lights connector etc on the airbox. There's a nice tidy passage to the diagnostics under thd seat
How do you get behind clock lol I've run it down the plastic channel which takes me straight to the diagnostics plug ... It's mainly the bit of wire from display to tank ... Everywhere I put it the wiring caught on the steering ... Will see if I can tuck it under the fairing stay tomorrow ...
I've put mine in the same place as slick and just run the wire under the tank cover. There are already some cables running that way - I just cable-tied them together. Then just under the seat at the back of the tank. Sorted
Well easy to move around as the wire is already under the tank and in the wiring channel under the seat so will have a play around again tonight...
There was no way it could stay where it was with tidy wiring ... From your pic it looks cock eyed but realised when looking there is a perfect flat spot above the clocks which means I could follow the ignition loom to the tank ... Happy now (I like things to be right! )
