Gear indicator
Discussion in 'Wanted' started by mk3golfcab, Apr 30, 2020.
  1. mk3golfcab
    mk3golfcab Elite Member
    Wanted for 2011 blade please :)
  2. Kilr'b
    Kilr'b Active Member
    New or used?
  3. Kilr'b
  4. mk3golfcab
    Ideally after a used, can’t justify the Healtech price at the minute, I don’t want a cheap Chinese job so was hoping for a second hand healtech or similar :)
  5. Mr_Chin_LK
    Mr_Chin_LK Well-Known Member
    Now this is something, my cousins did get right!
    I have a cheap Chinese one (and a gear indicator)
    I paid £21.00 from E of the Bay delivered. Took a month to get to me, but really well made and easy to fit (plug and play literally). To set it, you just ryde down a road and upshift when the unit prompts you to. Then just ryde. Sorted.
    I've had it on for three months, trouble free so far, so only time will tell its fate or not.
    So something to not overlook in my opinion.
    Just my ten pence worth!
    Chin
  6. Selmer50mark
    Selmer50mark God Like
    Can you not count ,,,,,1 down 2up3up4up Er o_O dam
    • Funny Funny x 6
  7. mk3golfcab
    It’s purely to know how many gears I need to knock down to power wheelie and pull the local skirt Mark :D
    • Funny Funny x 4
    • Optimistic Optimistic x 1
  8. Selmer50mark
    • Funny Funny x 4
  9. Gravel trap
    Gravel trap Senior Member
    I've an acumen on mine and its great carnt fault it .
  10. edderby
    edderby Active Member
    Doing without is a good way of improving your mental arithmetic!
    1000rpm = (approx)
    7 mph in 1st
    9 mph in 2nd
    11mph in 3rd
    13mph in 4th
    14mph in 5th
    15mph in 6th
    So, if you're doing 12,000rpm and the speedo says 180mph then you're in 6th, likewise if you're doing 1,000rpm and the speedo says 7mph then you're in 1st. Simples (ish)
  11. Kevin1
    Kevin1 Elite Member
    Even simpler if you let a gear indicator do the sums for you. One less thing to worry about.
    • Agree Agree x 2
  12. mk3golfcab
    Bump. Still looking
  13. DazK
    DazK Active Member
    Try Demon Tweeks Liam. PZRacing plug n play touch screen @£73. Debating it myself now with the QS on:D
  14. mk3golfcab
    Thanks Daz,, will check it out :)
