Gear selector rod issue
Discussion in 'Maintenance' started by Yorkshire Tyke, Apr 10, 2019.
  1. Yorkshire Tyke
    Yorkshire Tyke Elite Member
    Hi guys haven't been on here for ages but have an issue with my 675. It's been sat for a month while I've been away so took it for a spin for half an hour and ended up with this problem... Basically I stopped the bike and when I got back on it and set off I could only get up to second and the selector that you move with your foot now moves way more than it did before. If I take all the linkage off and just leave the splined selector shaft bit on its own I can get hold of it and move it quite a bit left and right (rotationally). Pretty sure this play isn't correct. Any one have any ideas??
  2. nevsrevs
    nevsrevs New Member
    Have the splines worn on the shift lever? Was the pinch bolt tight?
  3. tuktuk
    tuktuk Elite Member
    That's normal.
  4. tuktuk
    tuktuk Elite Member
    Obviously you should be able to get more than 2 gears but that movement is there on my bike.
  5. Yorkshire Tyke
    OK thanks for the input guys. I'll have to look a bit further into it. Pinch bolt was tight and splines aren't really worn. It's like when you change gear there is now way more travel then there was before
  6. tuktuk
    tuktuk Elite Member
    I'm trying to work out how to post a vid to show you mine moving the same.
  7. Yorkshire Tyke
    Don't worry mate I'll take your word for it. I just can't work out how now the whole assembly moves way further than it did before
  8. nevsrevs
    nevsrevs New Member
    Mark your shifter onto your shift bar to prove it ain’t slipping
  9. tuktuk
    tuktuk Elite Member
  10. Yorkshire Tyke
    I think mine is free play tuktuk. So when you move yours you are changing gear right? The movement on mine is before it even tries to change a gear
  11. tuktuk
    tuktuk Elite Member
    No mate that's up to the point of changing gear. If I push it further it will change gear but that's just the slack between gears
  12. Yorkshire Tyke
    Found the problem... The pin that I have circled has snapped
  13. tuktuk
    tuktuk Elite Member
    Shit!
    Where abouts is that o_O
  14. Yorkshire Tyke
    If you take the whole clutch out its behind the basket
  15. nevsrevs
    nevsrevs New Member
    Detent shaft?
