Getting a rounded allen bolt out - any tips?
Discussion in 'Maintenance' started by ccr32, Dec 15, 2014.
  1. el-nicko
    el-nicko Well-Known Member
    Never met a mechanic/fitter who had much faith in extractors but I've met a lot who've had 'em snap off in a seized screw/bolt and then you're in even more trouble. :(
  2. Scott
    Scott Active Member
    I'm a mech. My snap on stubby easy outs are excellent. Been used many times
  3. RRoss
    RRoss Active Member
    That's what happens when you buy cheap ones off eBay:eek:
  4. el-nicko
    There's always two! :D
  5. scooby
    scooby Elite Member
    no,i'd say theres always 1.
  6. Agent64
    Agent64 New Member
    Drill the head of the bolt off, then move panel out of the way, and hopefully there is enough of the bolt to get hold of with molegrips.
    I would make sure you copper slip the lower panel bolts especially the ones that go into wellnuts as they always seize.
    Good Luck.
  7. el-nicko
    Me too mate, but not down at the 'dainty' end of the trade. Me and me fellow 'gorillas' are dealing with heavy plant and forestry machines. We tend to be a bit harder on kit than your average 'spanner monkey'.;)
  8. Mike07
    Mike07 Active Member
    Try a left handed drill bit
    Mike
  9. ccr32
    ccr32 Active Member
    Is that like a left-handed screwdriver? :)
    (no really, I have to ask, as I'm genuinely not sure!)
  10. Mike07
    I'm not being silly, sometimes using a left hand drill, (Drill slow) it will wind out the offending bolt before drilling it out. Centre punch the bolt then give it a try.
    Mike.
    #30 Mike07, Dec 15, 2014
  11. IcarusGreen
    IcarusGreen Elite Member
    Easy out / stud extractor.
  12. arthurbikemad
    Torx bit as said
    Slot it as said
    Left hand drill bit as said
    Weld another bolt to it
    Snap on bolt/stud remover (looks like a drill chuck)
    Failing that
  13. ccr32
    ccr32 Active Member
    Ah, I think i've got one of those in the shed - will give that a try ;)
  14. arthurbikemad
    Glad to be of help, failing that try eBay they seem to have it all ;)
  15. Mike07
    Uri Geller also has a good line in extraction.
  16. Pitcrew1
    Pitcrew1 New Member
    Centre punch the edges to get it started, worked every time for me. Plus I never use the dome head type Allen bolts for that reason.
  17. restone
    restone Active Member
    Try an impact driver with a slightly bigger torx bit or flat head jammed across the inside, its basically a screw driver that you hit with a hammer and the blow causes rotation while maximmum downforce is applied from the hammer blow, great for seized or worn bolts.
    Most small garages, blokes with shed will have one that you could borrow, I'd happily oblige but live in the North of Wales.
  18. scooby
    scooby Elite Member
    problem with an impact driver is it needs a fair whack to make it work,not something I'd be using on a bike bracket
  19. tim grant
    tim grant New Member
    you can get "easyouts" !!
    You drill a 4mm hole into head then wind the easyout into the hole with a spanner/socket & it bites into bolt & will undo it.
    They are very good & easy to use & cheap
    Tim Grant
  20. restone
    Yes agreed mate only really suitable for robust bike parts
