Getting my Blade on the Road
Discussion in 'Maintenance' started by samuk, Apr 6, 2019.
  1. samuk
    samuk Well-Known Member
    Hi All..
    I bought a new blade back in 2015 - it had its first service think at 600 miles a year later..
    Have covered 800 miles and has been sat in the garage
    Going to get a MOT and service...should i be looking to change anything other then the Oil & Filter?
    Sam
  2. Barstewardsquad
    Could be worth a brake fluid change if 4 years old, and possibly coolant.
  3. hitch
    hitch Elite Member
    Brim it with the fresh fuel, whatever’s left in there will be a bit manky
  4. samuk
    Thanks guys..
    Thinking I will attempt the oil and filter myself to start with..
    Do you know oil and quantity u need? If this a fairing off job? As not taken them off this bike before..done the 09 and 05 blades..hoping its similar.
    Thanks
  5. tuktuk
    tuktuk Elite Member
    Ive always used 10w40. Think 4l covers it with a little spare.
    Best to remove belly pan but shouldn't need to remove side panel. Maybe the bolt nearest your footrest to allow some space to access the filter.
  6. Stuish
    Stuish Senior Member
    I think the manual asks for 3 litres. Found it best to fill up a 1L jug three times ,then you know exactly how much has gone in. And as mentioned above, bellypan is a must, but that's not too tricky to remove at all.
  7. samuk
  8. Stuish
