GiPro gear indicator question ?
Discussion in 'Mods, Upgrades, Accessories and Products' started by RepsolPaul, Dec 27, 2013.
  1. RepsolPaul
    RepsolPaul Well-Known Member
    Looking to get a GiPro gear indicator, it seems that it uses the diagnostic plug.
    Heard that my Datatool may use the same plug or other accessories/Power Commander and not possible to have more?
    Any help would be most appreciated.
    Cheers
  2. Muffking
    What year is your bike as the RR4-7 connects in line with the clocks.
  3. RepsolPaul
    2009
    Cheers
  4. Skippy79
    Skippy79 Active Member
    otherwise get an acumen plug and play gear indicator, it goes between the clocks and the loom, very easy to install
  5. BikersDiscountStore
    Gipro uses the ecu diagnostic socket which is otherwise unused. Datatool, PC or Acumen do not use it.
  6. RepsolPaul
    Thanks BDS, just didn't want to have it and it interfere with other bits !
    Cheers
  7. BikersDiscountStore
    Don't worry, it doesn't. Oh and there's a forum discount available. Call me in the new year if you want one.
    Regards,
    Mike.
