GoPro 5/6 Black Batteries & Charger
Discussion in 'Lounge' started by Barstewardsquad, Jun 4, 2020.
  1. Barstewardsquad
    Was looking for a spare battery. Normally go for official ones but saw Ravpower did 2 batteries and a charger for less than the price of 1 gopro battery.
    Best bit is the normal price is £15.99 but Amazon have a £2 voucher, and the seller has a code to reduce the price to £5.99, and the Amazon voucher works as well so ended up paying £3.99.
    https://www.amazon.co.uk/dp/B077P72HFR/ref=cm_sw_r_cp_awdb_t1_fTt2EbRT7VG20
    The promo code is under the Special Offers For This Item bit.
  2. F1CT1C10U5
    F1CT1C10U5 Well-Known Member
    GoPro firmware might block those batteries. Check before you buy.
  3. BladeOfGlory
    BladeOfGlory Active Member
    Hope yours are good but the RAVpower Go-pro batteries I bought are abysmal.
    They were okay to begin with but now last a fraction of the time of the official ones, to the extent that you put the battery in and the % drops by 5-10% every few seconds as you watch it. One battery much worse than the other as well.
    I'd go for more expensive or official ones now...
  4. Barstewardsquad
    Not a problem as from Amazon so will just return them. Is that a problem on older GoPros, thought it was only fromnthe 7 or 8 onwards?
  5. Barstewardsquad
    Worse case scenario I have a dual charger for £3.99 ;) I also have a Garmin camera and the non-OEM batteries on there aren't great but have rescued me a few times so fingers crossed on these ones.
  6. BladeOfGlory
    true that - useful having a multi-charger and Spare batteries are good to have in a pinch!
  7. F1CT1C10U5
    At least from 5 onwards, after version 1.55, aftermarket batteries were blocked. Don't know if it changed in the mean time.
  8. Barstewardsquad
    Both recognised fine by the camera and recorded for just under 90 minutes.
