gsx-s 1000
Discussion in 'Other Bikes' started by derchef, Feb 8, 2016.
  1. derchef
    derchef Well-Known Member
    Went last week to suzuki dealer for look at gsx-r 1000 special discount offer , ended out buying a gsx-s 1000 in mat grey mat
    After cb1000r and s1000r in 2015 got the suzy
    I will make soon my own 1000cc naked bike (garage)compare test :D
    Was also looking at tuono factory 1100 or superduke 1290 but well 90-120 days waiting time :rolleyes:
  2. sps170373
    Nice bike, looks good in the grey colour scheme
  3. sinewave
    U have too much disposable income Derchef! :rolleyes:
  4. derchef
    cause U did not see last mod. on my cb1000r :D
    #4 derchef, Feb 8, 2016
  5. derchef
    bought 4 indicator a tidy tail , brake/clutch levers and a nice end can
  6. derchef
  7. Slimwilly
    Slimwilly Member
    My mate has the 750 gixxer,he had the Yoshi can as new but it made no difference to the bike noise,,the bikes silencer was built under the engine ,big lump of tin box,,then the end can on that..odd really,needed a link pipe and end can I rekon.
    Anyway another of my mates has that Suzi and is well happy, same colour too
  8. derchef
    yes ,arrow header are available , but must reflash also the ecu
    i m looking for rear shock swap as well :p
    #8 derchef, Feb 14, 2016
  9. Tonic
    Tonic Active Member
    You may be able to cut the CAT off (or silencer as it's put earlier), that's what I've had to do with my Gixer 750. Sounds stunning now!
  10. derchef
    yes for sure , but arrow header are quite best/clean solution
  11. Tonic
    Tonic Active Member
    Yeah, the arrow solution is obviously the best, but their not cheap and you'll need to disable the set valve and have it remapped.....all depends on funds I suppose.
  12. derchef
    i will reflash the ecu at home , it s a suzuki not an honda :D
    Gsx-s are soffer of lean set up , pc5 or reflash is a must
    (disable the valve can be done with a norm. eliminator if U will take the engine out)
  13. derchef
    went today to pick her up
  14. exuptoy
    exuptoy Elite Member
    Very nice, and ABS that works:p
  15. martinowen
    That looks quite nice
  16. derchef
    did something also to her :D
