I have some Rizoma indicators for the rear of the 'blade, but I think I need to fit a resistor in line somehow so that it doesn't affect the blink rate. I got some Rizoma resistors, but I have no idea how to insert them into the wiring. It's not a simple plug or splice for wiring. Has anyone fitted some LED indicators to their bike and got a how-to ... or pictures?
Oxford or motrax do some short leads that have bullet connectors one end and oem fittings the other is what I used to splice my aftermarket rear led brake/indicators in
You could always buy a LED relay instead and replace the stock one that sits on the headlight. Fitting the resisters in line is fairly straight forward tbh, plenty of info on you tube etc. If you don't want to cut into the loom then cut the ends of the stock indicators leaving the push fit connection in place with a couple of inches of wire to connect the resistors.
