heat gun
Discussion in 'Non Bike Related' started by bonjo, Oct 13, 2018.
  1. bonjo
    bonjo Active Member
    Looking to get one for occasional DIY use.
    I want it to do heat shrink tubing and the odd paint stripping and plumbing or undoing stuck nuts& bolts
    Seen 2000w hair drier style @ £15~18 and a mini one (300w only) @ £11
    What do you guys use and have any recommendation on what to look for?
    thanks
    PS some have what I call knuckle bumper. Is it necessary?
  2. Barstewardsquad
  3. bonjo
    bonjo Active Member
    yes that's one I am considering. can you use it standing it on its back?
  4. Cream_Revenge
    Cream_Revenge Active Member
    Personally i wouldn't use my heat gun on shrink wrap, it gets mental hot. I use wife's hair drier for that.
    Mine is a £15 eBay job 2000w and been fine for a few years.
  5. Cream_Revenge
    Be careful near paint. Rule of thumb, if it's too hot for your hand, it's to hot for the paint.
  6. bonjo
    bonjo Active Member
    I was talking about electrical shrink tubing you put on cables & connectors. At the moment I use matches:eek:
  7. Spygoat
    Spygoat Well-Known Member
  8. Muffking
    TBH for that kind of stuff you can get away with a lighter, although I use the exhaust hole on a gas soldering iron.
  9. Barstewardsquad
    Yes. There is a folding bit of metal at the base if the handle, use that to support it.
  10. Barstewardsquad
    Works fine, I use lowest heat and keep moving it. Better than using the butane soldering iron that I sometimes use :p
  11. bonjo
    bonjo Active Member
    Thanks guys,
    I'll go with silverline it seems to do what I want and good price (15£)
    the wagner also looks good but much more expensive
    buying a wife in order to use her hair drier is not an option for me and far too expensive & troublesome:)
  12. Spygoat
    The return policy on those is simply terrible. No customer support either.
  13. Kentblade
    Kentblade God Like
    We have a Black & Decker KX1650 we use daily at work on shrink wrap and other items, just a quick flash over at low temp and job done, been used for years without issues.
    Doubles up as a t shirt dryer, glove drier and dribble dryer for one of the old guys as well.
  14. bonjo
    bonjo Active Member
    ended up buying the wagner from my local homebase, reduced to £13:eek:
    doesn't have the nozzle accessories but has a 4 year warranty.
    now I can my steaks a nice finish:)
