Hello from Sunny Scunny
Discussion in 'New Members' started by Joncal4, Apr 10, 2020.
  1. Joncal4
    Joncal4 New Member
    Hi to my fellow riders bought a Fire blade of a friend as a project it had two bent valves front head which i am currently rebuilding but have dropped a clanger ,i didn't separate the valve tops and shims, so I've read some of my Haynes manual for info ,does anyone know of which shim goes where , the sizes are 180 x2 195 x1 190x1 any help appreciated its on a 96 plate P
  2. Boothman
    Boothman Elite Member
    Hi and welcome to the forum
  3. Barstewardsquad
    Welcome!
    I'm not in anyway mechanical but wouldn't the shim placement depend on the valve clearance required?
  4. Boothman
    Correct @Barstewardsquad - me thinks you need your feeler gauges @Joncal4
  5. Blade runner 1
    Blade runner 1 Elite Member
    Hello and welcome, assuming you have replaced the valves the existing shims could now be irrelevant.
  6. Joncal4
    Joncal4 New Member
    Thanks for the reply, I'll check the cold valve clearance, the exhaust valves are new inlet are original and a have been re lapped, as the tops of the valves are recessed for the shim, would it not require a shim so the cover fits over the valve correctly
  7. Mr_Chin_LK
    Mr_Chin_LK Well-Known Member
    Hi and Welcome to the forum!
    Chin
  8. mk3golfcab
    mk3golfcab Elite Member
    Hi and welcome :)
  9. Selmer50mark
    Selmer50mark God Like
    Hello and welcome
    I think your cam shafts will be in and out a lot till you get the right gap o_O
  10. Philip
    Philip Active Member
    Hello and welcome
  11. BlackDevil
    BlackDevil God Like
    Hi and welcome !
  12. PauloHRC
    PauloHRC Moderator
    Hi and welcome to the forum!
    Sounds like you'll have something to do while isolating ;):D
  13. Joncal4
    Joncal4 New Member
    LOL are you spying on me ?.
    I've got the inlets sussed out but the exhaust with the 195 &190 shim is giving me no clearance at all so ill be looking at parkers for some slightly smaller shims probably about 170/160
  14. bradt
    bradt Elite Member
    Welcome
  15. Joncal4
    Joncal4 New Member
    Thanks
  16. Black & White
    Black & White Well-Known Member
    If you have smaller shims on any inlet valves, you may have to borrow them for the exhausts so that you get a measurable clearance. You can then order the correct ones. It may be helpful to make a chart. "Valve number" / "Existing clearance" / "Existing shim" / "Required shim".
