help on oem rearset fitting
Discussion in 'General 1000RR Discussion' started by keithg1748, Apr 26, 2015.
  1. keithg1748
    keithg1748 Active Member
    hi can anyone give me advice on fitting the gear change lever , i have a bolt , wavy washer , and a normal 8mm washer , i have also used semi lock thread , when i do the bolt as torque spec the bolt comes lose on gear changes and if i tighten beyond torque the spec the lever doesn't move , any ideas where i am going wrong , thanks for any info.
  2. PeterT
    PeterT Active Member
  3. keithg1748
