Help please to identify flywheel
Discussion in 'General 1000RR Discussion' started by lambchops, Apr 3, 2015.
  1. lambchops
    lambchops Elite Member
    Well broke down as some of you know, stripped it today and the stator is burnt up, not to bad but very fried on the wires. Now I know the guy replaced this before I bought the engine so its done 6K miles, seems to be an aftermarket one also.
    Now I suspect I have the old type flywheel, but can anyone identify it to be sure?
    [​IMG] [​IMG]
  2. scooby
    scooby Elite Member
    i'm guessing the only real way to tell would be to find the part number on it (should ahve a mel stamp) then check against a parts fiche
  3. lambchops
    Yeah its on the back Scooby.. Need a tool to remove it before I can do that :(
  4. Haggler ®™
    Haggler ®™ Active Member
    Just a thought........and this is hear say..............someone fitted a 929 set to their 04/5 ,the only thing they had to do was extend the wires ..................you,re pretty good in that department I beleive ?
    Better odds getting a 929/954 set than buying old 04/5 set
    But like I said.........Hear say
  5. lambchops
    Ah ok good to know :)
  6. scooby
    scooby Elite Member
    it's just a 14mm nut from memory,but it might be on a taper aswell (it's been a while since I stripped an earlier blade engine)
  7. lambchops
    Ok thanks Scooby, thinkng of just replacing stator as want it back up and running by next weekend.. New one on ebay from UK for 90 quid at the moment may just buy that for now and revisit next winter..
  8. Stumoores
    Stumoores New Member
    It's on a taper and you need a 20mm threaded tool to remove it. My old stator (rr5) is in the garage if you want a picture
  9. Stumoores
    Rotor not stator duh!
  10. scooby
    scooby Elite Member
    I do remember stripping my engines into component parts and don't recall needing anything special to remove it,just that it was on a taper,unless I'm getting very forgetfull in my old age :oops:
  11. Haggler ®™
    I find in most cases if you get two hammers and gently tap the flywheel 180 deg apart at the same time it's enough to shock it off the tapper............gently! I said !
  12. Dave
    Dave Member
    As Stumoores says, M20 threaded flywheel remover is required. Remove the M10 bolt with 14mm socket/spanner, screw in M20 flywheel remover whilst holding the rotor across the 2 flats with adjustable spanner, tighten the flywheel remover as much as you can put a blanket or similar under the motor and give the flywheel remover a tap with hammer. Sometimes needs more of a whack:eek: than a tap and off she comes.:D
  13. lambchops
    Well went for the UK stator for £90 new, will get me up and running and will revisit for a proper fix over the winter providing it lasts the summer lol
