Just getting the blade ready for Almeria and although ive run her a few times today.........she now wont start but does turn over.....im hoping its just battery which as I type is on charge.....but during the day I have been getting odd error code being logged in HM dash......bank sensor ? although at mo no codes present any ideas ?? Is Uncle Arthur out there ??? or anyone please !!!!!
You need a good Electrician Rob! If it's turning over OK then it aint the battery. Have you checked the obvious for continuity, Kill switch, Side stand switch, in gear etc? Sporadic error codes quite often emminate from a loose connection/earth etc
Sometimes people running external supplies and advising on 30Ma protection has to take a back seat................. !!
Kill Switch contacts eh Rob! Thought you'd checked that? Glad it's sorted matey, I know how it is missing sumat that you as a Spark should identify easily yet don't! I spent 2 hours fault finding a daisy chained comms cable in a suspended ceiling on a big Air Con system showing a Comms error code that turned out to be a lack of a 30V DC signal from the outdoor unit due to a tripped breaker!
