Hi all from West Norfolk
Discussion in 'New Members' started by Festa, Jun 23, 2022.
  1. Festa
    Festa New Member
    Getting back in to bikes again after a long break, looking at a 2015 in Repsol colours :)
  2. Boothman
    Boothman Elite Member
    Hi and welcome to the forum - read on here about the ABS and form your own opinion before putting a deposit down. However, if the reg is PF15 UON walk away unless you buy it with your first intention to be removing the ABS, or someone has already removed it.
  3. Barstewardsquad
  4. Blade runner 1
    Blade runner 1 Elite Member
    Hello and welcome
  5. Festa
    Festa New Member
    Tha
    Thanks no it's not that reg, pretty sure it's not got abs
  6. Festa
    Festa New Member
    Actually just asked and does have abs. Best I have a read up on that then
  7. Lozzy
    Don't waste your time reading up....unless you're prepared to rip it out. The system isnt fit for purpose. Find a non abs, they are some out there :)
    • Agree Agree x 3
  8. Festa
    Festa New Member
    So does this effect all years including the 2015 Repsol, is there a fuse that can be pulled to turn the ABS off, was very close to buying a 2015 yesterday
  9. Boothman
    2008-2016 I know some have pulled the fuse rather than remove the system but then your dragging 10 or more kg round as ballast. Honda scrapped their own ABS for the 2017 model and went with a Bosch system (speaks volumes that they’d spend money buying it in if there was no issue with their in-house kit)
  10. Festa
    Festa New Member
    I guess pulling the fuse makes it safe, but as you say 10kg is a big bit of useless weight to carry around
  11. Lozzy
    You could always go on a diet to offset the 10kg lol.......or work on your biceps to be able to push it around if you don't fancy lettuce buttys
  12. Festa
    Festa New Member
    Haha I could do with dropping 10kg
  13. Boothman
    Or avoid the hassle and get a none abs - you’ll also avoid hugger issues that way (the ABS bikes seat under-tray sits a lot lower)
    #13 Boothman, Jun 23, 2022
    • Agree Agree x 2
  14. bradt
    bradt Elite Member
    Hi and welcome, good luck with the search as others have said avoid the early abs
  15. Coda
    Coda Active Member
    Yes pulling the fuse disables the ABS then it behaves just like normal brakes. I haven't had an issue with my ABS yet but I am prepared to rip it out the day it gives me even a hint of gip.
  16. Boothman
  17. rewy..rr
    rewy..rr Active Member
    welcome
  18. BlackDevil
    BlackDevil Elite Member
    Hi and welcome !
  19. Jay Floyd
    Jay Floyd Active Member
    Welcome along
