HM Dash Information window
Discussion in 'Mods, Upgrades, Accessories and Products' started by si1000repsol, Jun 19, 2015.
  1. si1000repsol
    Finally have the bike back up and running but have two issues
    1. The bike when cold and starting says 101 degrees? it then quickly states HI.
    2. The right hand window has no icons for oil indicators etc. Is this something that needs to be setup?
  2. sps170373
    Make sure your running the latest software which is version 7I from memory and that you are running right model year
  3. si1000repsol
    Yes 7I and its set for CBR1000RR 2009 so very strange
  4. lambchops
    lambchops Elite Member
    You can turn the warning lights on and off in the settings.. Make sure they are enabled :)
  5. lambchops
  6. si1000repsol
    So under Warnings section, this disables the information on the right hand side? I'll give that a try tomorrow
  7. lambchops
    Yep that's it, think it's disabled by default... Sure mine was.
  8. si1000repsol
    I'll give that a try :) and check the wiring for the ECT as there is no way its 101-106 degrees cold!
  9. carter
    carter New Member
    You got it in °C or °F lol
  10. si1000repsol
    That did cross my mind but no idea how if you can switch from Celsuis/Centigrade to Fahrenheit or how to! Their documentation is rubbish!
  11. lambchops
    You got documentation? Wow lucky you :)
  12. Barstewardsquad
    Even if the display is in old money that is still warm. About 35-40 centigrade under the old rule of double it and add 30
  13. sps170373
    You really need to play with it more! There's loads of stuff that can be changed Si
  14. si1000repsol
    Right, I found the setting to change it to Celcius/Centrigrade from Fahrenhight but now just shows HI. I even set the warning Temperature to 118 degrees.
    The warnings were all set off and changed to on but still no information on right hand side. I did find that the warnings work with the lights at the topbut nothing for the right hand side window.
  15. RepsolRuss
    RepsolRuss Active Member
    Mine says HI as soon as it's turned on.....
  16. si1000repsol
    Does it then change or stay at HI?
  17. RepsolRuss
    I honestly can't remember lol. I'll have to check
  18. Barstewardsquad
    Does the temp show on the standard dash newer blades below a certain temp?
  19. si1000repsol
    Yes it does and that's what is strange as I am sure it should show temp from cold like stock I imagine. I went into data and it said my bike cold was 204 degrees Celsius!
  20. sps170373
    Think that's a bug Si as that is for top temperature as mine shows the same 204c
