HM Dash Information window
Discussion in 'Mods, Upgrades, Accessories and Products' started by si1000repsol, Jun 19, 2015.
  1. si1000repsol
    Well hopefully thats something thats sort with Bios 7J :) I guess now I have to work why I have nothing on the right hand window when I have all the warnings set to on.
  2. Drew
    Drew New Member
    Hi,
    Did you get a resolution?
    My HM dash flashes Low temp regardless of the actual operating/ engine temp. When I display the 'data dash,' no temp reading is shown.
    The OEM dash shows the temp correctly.
  3. si1000repsol
    It needed a circuit board to fix it for me so sent the dash off and it now works a treat
  4. Scott
    Scott Active Member
    just check what temp the dash is meant to start reading temperature at. mine was set to 80!
  5. Drew
    Drew New Member
    That's the final option that hm in Aus are telling me, though he hasn't come accross this problem.
    I was hoping it may have been as simple as a setting work around, or a dodgy backplate.
    Thank you
  6. si1000repsol
    Yes hoped mine was the backplate but sadly not.I also tinkered with the temp settings but never worked for me.
  7. Drew
    Drew New Member
    Spot on,
    HM have sent me an e-mail to send the dash back - PCB error
    Thanks again
