Fitted the plus today on my rr6. ,al went well, test rode it. Thought id just fine tune the settings, but weni looked at the module to adjust the settings it was all frosted and reading swaheeli. Could not make it to read normal. Anyone eperienced this? Or hav i just purchased a duffer
Did you buy new or second hand? Double check all the connections as the lcd display takes power from the coils
It was new dude. I didnt know the lcd took its feed from the coils. The bikes running perfect so i wouldnt suspect that it is a poor connection on the coils, but reluctantly ill have to strip it down again to check. I also double checked that they all fitted snugly with a nice click, but you never know. Many thanx
Most common cause for LCD failure is a poor earth. Where is it earthed? Check the earth is good and not on the rocker cover or something like that which has a gasket. Its quite easy for us to tell when the unit is back wether a good earth contact was made as one component on the board heats up and changes colour. When under load the amp draw is quite high, higher than you would expect so this is why a good earth point is needed. Also, going to the frame without exposing the bare metal is not good either. If the earth is all good then send it back for a replacement including your proof of purchase from the store you got it from
[Qmany thanx for your reply toby, i,ll check it all out today and hopefully rectify, if not i,ll return as advised. Thanx againUOTE=Toby LeRone;312530]Most common cause for LCD failure is a poor earth. Where is it earthed? Check the earth is good and not on the rocker cover or something like that which has a gasket. Its quite easy for us to tell when the unit is back wether a good earth contact was made as one component on the board heats up and changes colour. When under load the amp draw is quite high, higher than you would expect so this is why a good earth point is needed. Also, going to the frame without exposing the bare metal is not good either. If the earth is all good then send it back for a replacement including your proof of purchase from the store you got it from [/QUOTE]
