Honda dark taller screen
Discussion in 'Mods, Upgrades, Accessories and Products' started by Gazza13, Mar 17, 2012.
  1. Gazza13
    Gazza13 Member
    Has anyone fitted the genuine Honda tall dark screen to their 2011 repsol blade?
    I got mine today but not to certain about the black cover you get with it to keep the sun of the clocks!
    So who has fitted the cover and who hasn't fitted it?
    Thanks
    Gary
  2. Rob
    Rob Administrator
    Hi mate. I've fitted it to two bikes. I didn't bother with the shield on the second one. It's to stop the sun magnifying through the screen and melting the lens. But I don't think it ever gets hot enough in the uk to need it.
  3. PeterT
    PeterT Active Member
    Me too, i did not bother with the clock protector was told it was for sunnier climates like the USA
  4. Mogsy
    Mogsy Active Member
    I fitted it, it lets me see my GiPro gear indicator much easier in the daylight so I like it
  5. drewl999
    drewl999 Active Member
    How much was the screen? I'm fancying one for mine. Does the high screen make a big difference.
  6. Gazza13
    Gazza13 Member
    I paid £92 from Marshall Honda peterborough. This is for the repsol so comes with screen sticker.
    I noticed a screen on ebay(said brand new not been fitted) that went for £82 with delivery! Also so done on here was after £30 for just the sticker!
    The screen should have been £110 but they gave me 15% off.
    Thanks
    Gary
  7. drewl999
    is the screen sticker already attached or did you have to put it on yourself?
  8. Gazza13
    Gazza13 Member
    Put it on myself! Comes with complete instructions. Just sprayed sticker (sticky side) with mild detergent then use a squeegee to remove any bubbles and liquid.
    Hardest bit was trying not to snap the two lower locating pegs! And yes both snapped!!! Grrrrrrrrr
    Very good fit! But then again it should do from Honda and the price.
    Thanks
    Gary
  9. RedMacGregor
    RedMacGregor Active Member
    You have to put it on yourself unfortunately. What's the issue with these lower lugs. I've got a screen to fit as soon as it gets a bit warmer. Is there anything you can do to prevent them breaking (dremel) fow examlpe or warm the plastics up??
    #9 RedMacGregor, Mar 18, 2012
  10. Gazza13
    Gazza13 Member
    The lugs are weak. You need clearance to pull the screen off the lugs, any pressure and they just snap! No big deal as there is a fixing at the base of the screen and this holds the screen in place.
    Thanks
    Gary
  11. JM1
    JM1 Active Member
    To avoid breaking the lugs...loosen the mirror mounts and be careful!
  12. Gazza13
    Gazza13 Member
    I did that! I took both mirrors off only leaving the indicator wire holding indicators!
  13. HRCTrev09
    HRCTrev09 Well-Known Member
    Me too and they still snapped :mad: your either extremely fortunate or an expert not to break them off :) they might have made the of a lot stronger stuff like balsa wood :D
  14. JM1
    JM1 Active Member
    They snapped because you exerted force on them :eek:
    You have to be CAREFUL.
    In other news, I broke a tail piece because I removed and refitted it a number of times, eventually got impatient and stopped being CAREFUL :)
