HRC catch bottles/bracket
Discussion in 'Wanted' started by jamesm09, Dec 24, 2014.
  1. jamesm09
    jamesm09 Senior Member
    Hey I'm after one of thoses brackets for the overflow catch bottles. Seen loads of bottles on eBay but no brackets for the 06 Fireblade. Only the 08+ comes up.
    Cheers!
  2. Scott
    Scott Active Member
    I got some bottles but sold the bracket
  3. Jase
    Jase Elite Member
    James you don't have to have these for racing as long as overflow pipes go into belly pan and belly pan is sealed and can hold any fluid that might leak out of bike .
    The lower fairing has to be constructed to hold, in case of an engine breakdown, at least half of the total oil and engine coolant capacity used in the engine (minimum 5 litres). The lower edge of openings in the fairing must be positioned at least 50 mm above the bottom of the fairing.
    #3 Jase, Dec 25, 2014
  4. jamesm09
    Cheers Jase. I'm picking up some fairings from Watford on Saturday so will have a look.
    Merry Christmas
  5. Muffking
    Pics or it ain't happening :D
  6. jamesm09
    There will be, don't won't worry about that!
