HRC Rear brake reservoir....
Discussion in 'Mods, Upgrades, Accessories and Products' started by Blackness, Apr 18, 2015.
  1. Blackness
    Blackness Active Member
    Morning fella's
    During my build over the winter i did away with the standard rear brake reservoir and stuck on one of them HRC little tube things. I also stuck in an Armstrong rear disc in the hopes of getting some kind of stoppage from the rear... I spent ages messing around trying to bleed it and didn't really get any joy and didn't feel like was doing much... I had ago again the other day and noticed it was a bit wet and was seeping a little at the base of the tube, so i tightened it all right up to the max, and tried bleeding it again which it a mission as the tube has sod all capacity i have to keep topping it up after ever pump with a syringe. Had another go yesterday too and still not getting any useful pressure out of it !
    What am i doing wrong ?
    Everything seems to be tight and torqued up and no obvious leeks...
    Is there a knack I'm missing ?
    I don't expect it to be like a proper brake or lock up, but just enough to stop me flipping if the odd wheelie happens ya know...
  2. Cbrjay
    Cbrjay Well-Known Member
    I never used the clips that came with it, on mine they pinched it and didn't seal very well
  3. Blackness
    What did you use then ? Ive got a jubilee on the bottom and a little sprung clip on the top !
  4. Cbrjay
  5. Cbrjay
    On mine I found jubilee punched it and wasn't holding it roundly if u get what I mean
  6. si1000repsol
    Yes mine leaked at the bottom jubilee clip too. I think mine was because it was fitted on the plastic tab so never made a good seal. I am also replacing the HRC tube with a tygon tube as it goes cloudy.
  7. graemewalker
    graemewalker Elite Member
    Blackness bleed with origional resivoir makes life much easier then replace tube,in all fact u don't need a tube it's cosmetic because the fluid in the master cylinder is enough after bleed but it allows for expansion when rear brake is activated
  8. Muffking
    I back bled mine. No risk of running out of fluid then.
  9. Gilesy
    Gilesy Elite Member
    I had some thing similar and just used a new piece of tube.. Stopped the 'damp patch'
    As for bleeding.. I bought a cheap £20 vacuum bleeder off eBay.. Brakes are so easy to bleed with this thing.. Let me find the link
  10. Gilesy
    Gilesy Elite Member
  11. Blackness
  12. Gilesy
    Gilesy Elite Member
    i never bothered buying the fancy tygon stuff.. the HRC stuff from Ebay is just as good..
  13. Blackness
    Im sure I've got enough to keep replacing it a few times too anyway, as i only cut a bit off to put on the mc !
  14. graemewalker
    Got some Hrc left about 5 inches yours if you want pm your address
  15. Blackness
    Cheers Graeme, but i think I've got about the same left over that came with the kit somewhere !
