Hugger fitting to a SP/2 - 2017/18
Discussion in 'Mods, Upgrades, Accessories and Products' started by Brom66, May 8, 2020.
  1. Brom66
    Brom66 Well-Known Member
    2, o.e & Honda accessory hugger, as you can see a bit of a trim needed to accommodate the wire protecter
    3 Hugger trimmed
    4, Paired up with wire protector used a bolt so the fixing holes lined up to be sure of alignment
    5, Fitted
    Not quite the right shape !!
    #1 Brom66, May 8, 2020
  2. stuart_g
    stuart_g Active Member
    I was thinking of getting one of these. Not sure if it will protect much more of the rear shock area than standard as looks the same height. Not too sure either if the side bits do anything. Does look nice though.
  3. Brom66
    I do agree it could be more protective, its about 15mm longer at best !
  4. Shutty
    Shutty Well-Known Member
    Waiting mine turning up
    Dremel already arrived
