Tags:
  1. CarbonMatt
    CarbonMatt New Member
    Can someone shed some light on wether a 08-11 rear hugger will fit a 12-16? Non abs model. Front hugger also? Much appreciated
  2. nigelrb
    Didn't we answer this yesterday?:confused:
  3. nigelrb
    I knew I'd seen it:
    Anybody know if an 08-11 rear hugger will fit an 2015 blade? Thanks
    #1000CarbonMatt, Saturday at 9:26 PM
    and the answer is the same, yes, but depends if it's ABS or non-ABS.
  4. vic_ster51
    vic_ster51 Active Member
    Generally no... the honda's aftermarket own one is super tight feels like forcing it when tightening bolts and rubs on 12+ shock res but it fits
    Non honda aftermarket ones are all different if listed for 08-16 you got come back if doesn't fit. Basically all depends how big they do the cut out by the rear shock res. As this is the only part that is the issue. Or if you find cheap one, just trim it abit. Cant be seen anyways really
  5. vic_ster51
    front huggers/mudguards all the same 08-19
  6. CarbonMatt
    Sorry maybe suffer from memory loss no joke. I’ll go threw my post cheers
  7. CarbonMatt
    Bumped my head few too many times if u wondering
  8. nigelrb
  9. CarbonMatt
