I have found the bike for me.
Discussion in 'General 1000RR Discussion' started by SIDEWAYS, Aug 7, 2014.
  1. SIDEWAYS
    SIDEWAYS Senior Member
    Being honest I have been looking at other bikes.Wanted something a little more upright and as good as my blade.I tried Ducati, KTM Aprilia and all the japs but found nothing that fits the bill they were all ok ish and had different things I didn't like about them.So I decided to look at bar riser options instead.Bought a pair of helibars for £85 to try ;)put them on and went out for a ride.Boy what a difference!! It is now the bike I wanted.A lot lighter on my back and wrists, I can hang off it better having a short body the reach is easier to get down past the mirror.And it is better through traffic.Honda should have made the cb1000r like this cos it would have raised the bench mark on the naked models.Feels like a tuono but alot more poke and handles just as great.So folks Helibars saved me from defecting and has made my blade easier to ride.Fitting needed nothing extra just a bit of rerouting the wiring and throttle turned under.Should have done this earlier.
    • Like Like x 6
  2. Daznorthwest
    Daznorthwest Elite Member
    God effort mate... Glad your back in love with your blade
  3. Carlo
    Carlo Active Member
    Nice one if i ever see a blade stunting some fat wheelies down the road ill know its you then with the risers lol
  4. SIDEWAYS
    It never crossed my mind ;)
  5. PeterT
    PeterT Active Member
    What Helibars were they please?
  6. SIDEWAYS
    Helibars part number is HB12034
    They are 1 3/4" taller,1" towards the rider and 2" wider.I bought these second hand off ebay stole em at £85 they normally go for between £120-£175.I kept umming and arring and these came up.Best money I've spent on it.Would have bought them new if I knew what difference it does.Unlike the other bar risers you don't need elongated brake lines etc.
  7. Barstewardsquad
    Do you have to modify the fairings?
  8. SIDEWAYS
    Nope!! nothing needs replacing nor cutting.The wiring on to the clip-ons have to be rerouted to the back of the forks, the throttle under so the two tubes are at the bottom.The front brake hose clamp on the bottom fork needs to be taken off.Rerouting is done whilst the top yoke is off.Looks daunting to start with but really is easy.The hardest part is getting the bar weights back in the Helibars.Use more lube did the trick.
  9. PeterT
    Is that part number for the Big piston forks 2012 onwards?
  10. Dave V
    Dave V Elite Member
    The outside diameters the same, so would imagine it's the same kit mate.
    Nice one Jezza, any pics?
  11. SIDEWAYS
    2004 to 2013 I believe.Your big piston forks I'm not 100% sure whether the diameter is the same as the earlier bike.I think it is but clarify this with Helibars to be 100%.
  12. Dave V
    Dave V Elite Member
    Outside diameters the same mate, fitted BPF's to my ten with the original yokes.
  13. SIDEWAYS
    Dave V just answered it for you.Piccies show 1st pic with Helibars second standard 20140808_164239.jpg tyres 097.jpg 20140808_164312.jpg 20140808_164328.jpg
  14. Jimbo Vills
    Seen bar risers on sportsbikes before and they've looked weird, but they look ace mate!!
    Glad it's worked out for ya dude ;)
  15. sinewave
    Got Giles Risers on mine also but in this case they are fully adjustable for bar angle along with a 40mm rise.
  16. sps170373
    Looks good sideways
  17. lambchops
    lambchops Elite Member
    Are the BPF 50mm or larger? Just wondered if they could be fitted to a rr4..
  18. Clarkey
    Clarkey Member
    That seems like a good ideas
  19. GaryS
    GaryS Active Member
    Love that Termi beautiful bike mate
    GaryS
