Idler Gear ‘16 Blade
Discussion in 'Maintenance' started by Ryan Robinson, Jul 5, 2020.
  1. Ryan Robinson
    Ryan Robinson New Member
    Right....Having a nightmare here. I’m not being daft in saying there should be a thrust washer and wave washer on the idler gear shaft of a 2016 Blade?
    Took the clutch cover off yesterday and for the life of me do not remember seeing either. Now panicking because I can’t find them to put back on !
  2. Kilr'b
    Kilr'b Active Member
    Check the bottom of the oil pan
  3. Kilr'b
    Strong bendable magnetic pickup tool will probable find them
  4. icedmind
    icedmind Active Member
    https://www.fowlersparts.co.uk/parts/5828554/cbr1000rr-fireblade/starting-clutch
    this wavy washer thing?
    Have a look at the clutch cover sometime the oil film stuck one washer against the clutch cover and as removing the wavy get drops below to pan; strong mag pick up or remove sump to get it out. And check the work area they can just drop out etc. I would check the diagram and make sure you have the right part at the right place
