Infill panel
Discussion in 'Wanted' started by mpitman, Oct 3, 2012.
  1. mpitman
    mpitman Active Member
    After my excellent purchase of a carbon akroprovic from Jamie (thank you Jamie ) I'm in need of an in fill panel, does anyone know where to get them and how much they cost?thanks in advance
  2. honda.ima
    honda.ima Active Member
    I am also looking for a infill panel to fit on my akro.
    I am sure some members have done this.
    Regards and thanks,
    Rob.
  3. ColinBR
    Leo Vince carbon fibre infill panel is what you are after.
    I got mine from moorespeedracing.
    I'll go fetch a link
  4. ColinBR
  5. honda.ima
    Hi and thanks payment completed.
  6. SIDEWAYS
    SIDEWAYS Senior Member
    Just fitted a yoshi shield on my ackro.For those fitting one you will need to put a spacer or washers approx 10mm on the long 12mm headed bolt.This 12mm headed bolt you can just about get to in the middle of the snake bit.This sequence on the bolt up to the 12mm head end: infill bracket on first then the spacer or washers then the large exhaust bracket washer.This spacer brings the bracket further towards where it should bolt up.Bolt it all up then set about getting it to fit right.You will have to bend the bracket a bit for it to line up properly.Use the top bracket as a reference point.The tag bracket which doesn't come in the kit I made up using a bit of tin with a tag on it and put a jubilee clip on the cat with the bracket tag under the jubilee dilled a 6.5mm hole and put an allen bolt through it. tyres 114.jpg
  7. honda.ima
    Finished fitting my Leo infill panel took 30 mins start to finish, thanks for the help finding the right one. DSC_0200.jpg DSC_0202.jpg
