Is it easy to remove the rear shock?
Discussion in 'General 1000RR Discussion' started by exuptoy, Feb 28, 2015.
  1. exuptoy
    exuptoy Elite Member
    Took out the back wheel yesterday and wanna remove the shock at the same time however I notice the linkage bolt all go though from the exhaust side so there's not enough room to extract the bolts. Don't need to remove the linkage but I do want the exhaust out.
    Am I missing something or will I have to pull the exhaust too?
  2. ColinBR
    Is it a standard OEM exhaust on the bike?
    If so then I'm pretty sure you do.
  3. exuptoy
    Bollix!!
  4. ColinBR
    I don't think you need to remove it completely though.
    I'm sure I read someone just undone the clamps and fixing points to twist it out I the way a bit.
  5. martinowen
    It's easier on yours than the underseat model as even the headers get in the way
  6. barry107
    barry107 Active Member
    It's straight forward to do;
    • Either place the bike up on an Abba stand or if you don't have one but have rearsets, place a car axle stands under each rearset as this unloads the suspension.
    • Loosen off the exhaust clamp
    • Remove the securing bolt to the hanging bracket and you can move the exhaust out of the way, if you want to remove it completely you'll have to undo the exhaust servo cable .
    • Now it's just a case of undo the securing bolts for the shock and removing it, take your time as it can be awak to get out and in without marking anything.
    #6 barry107, Feb 28, 2015
  7. barry107
    Video for you to watch;
    • Thanks Thanks x 2
  8. Blackness
    Blackness Active Member
    I've dropped shocks out of both my RR6 and my mates 09 and didn't touch the exhausts and only took about 30 minutes to do complete change !
  9. martinowen
    We left my exhaust on but would of been easier if it was off I think
  10. Slick
    Slick Elite Member
    Thanks for the Vid, though is makes me cringe the way he chucks that ttx around!.
    Just bought a new OEM shock too off BladeRR8, gonna fit it when the salt is all clear off the roads
  11. barry107
    whilst you have the shock off, take the suspension linkage apart and clean then regrease the bearings as they are a bit dry from nthe factory
  12. exuptoy
    Cheers for the advice peeps, I have now purchased an Arrow GP2, so it'll have to come off anyway. I suppose it makes it easier to put the bolts in the other way around so next time the access is easier for regreasing the linkage etc?
  13. exuptoy
    Following all your advice I decided to 'have a look'. 45 min later the exhaust was off, the linkage was stripped down for regreasing (it was dry but at least it was free), and the shock out and on the floor. Cheers all. Worse part looked to be getting the exhaust clamp off as it was seriously rusty but as I was twisting off the nut the clamp snapped in half.:)
  14. barry107
    well done exuptoy, it's a great sense of achievement doing it yourself.
  15. Moon
    Moon Active Member
    I'm going to be changing my rear shock soon, what type of grease will I need for regreasing?
  16. barry107
    LM Grease - Lithium based, high melting point grease, also suitable for general purpose applications.
  17. Remal
    I must get my ass in gear and put my new TTX shock in i've had ages. :oops:
  18. exuptoy
    Stole mine from work! :)
  19. barry107
    Is there any better type than the one borrowed from work? ;)
  20. barry107
    I'll test it for ya, just to make sure it will be working correctly for you!!!!! :rolleyes:
