I've had this bike for a year and I've decided that what I really want is another sports bike so this is up for sale. It wants for nothing and I've put a fresh mot on it today. It's in generally good condition but not mint as it's 15 years old and has just over 20k miles on it. It rides extremely well and the previous owner did his own servicing on it and looked after it very well. Notable things about the bike are... - ULEZ Compliant with EC Certificate of Conformity - Pirelli Rosso Corsa 2 tyres with plenty of tread. - Oberon Performance Clutch Slave Cylinder - Facet Solid State Fuel Pump 40171 - OEM Brembo Brakes all around - SAS EPC Valve Removal & Canisterectomy - X-Bikes Fuelling Set Up (MWR Air Filter, Carb Jets adjusted) - JCE Titanium Exhausts - Uprated Rear Spring (original included in sale) - Yuasa YTZ14S Gel Battery - Scottoiler Chain Lubrication System - 16T Front Sprocket (1 down / 2 up set up) - Black Short Racing Levers with orange adjusters - Gilles Adjustable Racing Foot Pegs - Aftermarket black wing mirrors - Ecliptech LED Engine Rev Indicator - Aftermarket rev counter - Headlight On/Off/Sidelight Switch Fitted (from Super Duke) - Fork air push to bleed valves - Top/Bottom Engine Crash Bobbins - Fork and Swing Arm Crash Bobbins - Black plastic frame protectors - 0.5mm clutch oil jet - New radiator pressure cap I'm based near Newbury if you want to see the bike. The going rate for these bike seems to be just short of £4k and I'm looking for as close to £3.5k as possible.
