kxf250 dirty fun project
Discussion in 'Other Bikes' started by Gravel trap, Dec 30, 2019.
  1. Gravel trap
    Gravel trap Senior Member
    I've picked this up cheap and am doing her up for a bit of fun whilst Mrs graveltrap is busy doing the uni work for her masters. I don't intend to keep it just make a bit to fund another project. it's a 2005 and was /is a bit rough. I've done a service of oil and filters new fork seals and oil as old ones leaking new grips throttle cable and hot start carb cleaned and new jets in a new chain and sprockets are going on ive done the valve clearance polished up the pipe and next its paint frame sort bodywork and shes done . 20191217_083147.jpg
    • Like Like x 8
  2. Gravel trap
  3. Gravel trap
  4. Gravel trap
  5. nigelrb
    So amazing looking at the 'slight' frame and swing arm after constantly seeing our 1 litre stuff!
    Good to see your garage/workshop space being used effectively.;)
  6. Gravel trap
    at the moment @nigelrb my workshop has the old dt 250 in the corner my rr4 the kxf and a mk 2 golf track car and a polo dune both belonging to my cus. I'm getting full !
  7. Gravel trap
    the 2005 is the last of the steel frame kawasakis the swingarm looks slight but is strong as alloy job. I'm tempted to give it a daytime mot but it's really got to just be a flip over job to fund another.
  8. mk3golfcab
    mk3golfcab Senior Member
    Had a kx125 post getting a job (schoolboy Mx days) loved it. Looks like a good find and will be even better when you’re finished with it
  9. Gravel trap
  10. Gravel trap
    I'm not happy with the compression so I'm going to strip and check /replace piston and rings 20200107_164731.jpg
  11. Gravel trap
    whilst waiting for new piston rings I've painted the frame . and started to clean up all brackets . 20200112_175514.jpg
  12. Gravel trap
  13. nigelrb
    I recommend that you and @exuptoy commence a collaborative project!:D (Beard not mandatory)
  14. Gravel trap
    I'm in . and I've a beard .
    • Funny Funny x 4
  15. exuptoy
    exuptoy Elite Member
    Me too. Ditto !
    • Funny Funny x 3
  16. exuptoy
  17. Gravel trap
    it's like looking in a mirror @exuptoy !
    • Funny Funny x 2
  18. nigelrb
    Not all positive though.:(
    I sure won't be seeing you two on Love Island!!:D
    • Funny Funny x 2
  19. exuptoy
    Thank fuck for that, although I knew that before you made the assumption as I’m not a vacuous oxygen thief so they would have no interest in me, :D
  20. exuptoy
