Leaking Brembo rear brake P234
Discussion in 'Maintenance' started by si1000repsol, May 25, 2015.
  1. si1000repsol
    I think I bought a lemon. I have a P234 Brembo rear brake and it's leaking a small amount of brake fluid out on the bolts clamping the brake together. Can these be returned/repaired or a bin job?
  2. Dave
    Dave Member
    Repair the caliper, pull it apart clean area where seal ring sits, new seal ring, put caliper back together job done.
  3. si1000repsol
    Thanks mate. Is it that simple? Any ideas where I can get the seals?
  4. Gilesy
    Gilesy Elite Member
    Well if a seal kit costs anything like the m4 calipers then hope your sitting down! I thought of doing mine till I saw the £200 parts cost!
  5. Gilesy
    Gilesy Elite Member
  6. Mike07
    Mike07 Active Member
    Go to a hydraulic repair place, they may sort you if you only need an O ring.
  7. N1xxl
    N1xxl Member
    Use the O ring from a drive chain. Perfect size I raced at Brands with this in as mine done the same as it was a numpty that rebuilt it before me.
  8. sps170373
    Here you go Si try this item on eBay!
    181278700741
  9. Mike07
  10. si1000repsol
    Thanks everyone so I assume there is I rings in between in each piece? I'll take a look so could be a fairly cheap repair
  11. ShinySideUp
    ShinySideUp Elite Member
    Si, make sure you choose epdm type seals as these are happy to live along side with brake fluid where as the nitrile and viton type allow brake fluid to seep through the rubber.
  12. Dave
    Dave Member
    As shiny side up says make sure you acquire a epdm seal, most bearing supply, hydraulic fitting suppliers will have them. You may have to take yours along to get the correct size/profile.;)
  13. si1000repsol
    Thanks everyone yes sent it off to be refurbished with all new seals. It's going to get pressure tested so I hopefully should get peace of mind of no leaks.
  14. Dave
    Dave Member
    Thats the beauty of a forum as good as this one, just ask the question and members are more than happy to help.;)
  15. Jarryd
    Jarryd Guest
    dont go to 1000rr.net, they will just tell you to extend your swingarm and install a twobros slipon!
    #15 Jarryd, May 28, 2015
  16. sps170373
    Isn't bandana wearing compulsory also? ;)
  17. sps170373
    Where you getting that done si?
  18. si1000repsol
    The link you suggested. I called them and explained what was happnening and they are goind to rebuild with genuine Brembo o rings and pressure test so should be good as new.
  19. sps170373
    Ah cool! Good to know for future reference, let us know how it goes
  20. si1000repsol
    hairline crack so time for a new caliper.
