Leaving battery disconnected
Discussion in 'Maintenance' started by CBRGav, Jan 23, 2018.
  1. CBRGav
    CBRGav Active Member
    Right so I've stripped my bike down ready fit a qs tomorrow, can i leave the battery disconnected or will it reset stuff that needs be left alone? Standard ecu etc just don't want bugger the immobiliser or ote
  2. CBRGav
    Thanks in advance
  3. Lozzy
    If you've the standard ecu it will be fine disconnected. Probably run a bit better actually, as it's a self learning system & if the bikes running a bit rough you can disconnect/re -connect battery , run up to fans kicking & that reverts it back to original factory setting.
  4. CBRGav
    Cheers mate all I needed know, already reset it but wasnt sure it would be ok over night, bloody postman took my qs back to the depot so can't rebuild it til tomorrow! thanks again
  5. levin
    levin Active Member
    It will be fine , I used to take my battery out for a couple of months at a time, before I had an optimate, just will reset clock time and rev light
  6. CBRGav
    Great stuff ill have remember set it all up again before I go out, cheers
  7. bonjo
    bonjo Active Member
    If the ECU loses its learnt settings (like a long period without battery), the best way to get a trouble free re-start is to turn on the engine without touching the throttle and letting it get to working temperature. I was told this by a master technician and has worked for me
  8. nigelrb
    *Watching Gav smile at the Post Office counter and then race home*:D:D
  9. Dave dunlop
    Dave dunlop Elite Member
    My battery comes out for 4/5 months with no issues so you shouldn't have any problems at all.
  10. CBRGav
    20180124_140716.jpg and we're on, can't wait actually go and ride it lmao. Just done a run through on paddock stand make sure it's fitted right, last time till Feb or March some time! Quite surprised how easy it was to fit in the end
  11. CBRGav
    20180124_140423.jpg does anybody know what that divvy little pipe is on left of the tank? Hoping it's a breather as can't see anywhere it could go
  12. nigelrb
  13. CBRGav
    I found that one, plugs into the maf sensor. This one's shorter and comes off the tank no leaks or anything just didn't seem go anywhere. Still got tank cover off as I'm waiting on k&n filter being delivered so will have to have a inspection before i finish it off
  14. CBRGav
  15. keithg1748
    keithg1748 Active Member
    glad your happy with the quickshifter mate ,
  16. CBRGav
    Cheers mate, can't wait get out on it:)
  17. Nigelg79
    Nigelg79 Active Member
    Fitted my QS recently too - that tube isn’t connected to anything. Must be a short breather. Enjoy the new toy!
  18. CBRGav
    Cheers mate, couldn't see anywhere it could go to, but thought best to ask rather than burn it lol
  19. Jez
    Jez Senior Member
    factory ecu reset to put it back to fuel learn mode. is disconnect battery leave 2 mins, reconnect start engine do not touch throttle then wait until the fan kicks in. done. It is worth doing this if you fit an end can and don't want to go to the expense of a map or pc
  20. Jez
    Jez Senior Member
    forgot to say when fan kicks in stop the engine with kill switch
