Measuring exhaust noise level
Discussion in 'General 1000RR Discussion' started by Blade runner 1, Jul 31, 2016.
  1. Blade runner 1
    Blade runner 1 Elite Member
    Anyone know the correct procedure for measuring a bike's noise level? For example;
    db meter settings flat or A weighted.
    Distance and position of mic in relation to exhaust opening.
    Engine rpm, is it a peak level or an average across the rpm range?
  2. SimonRR
    SimonRR God Like
    I just pop up to nearest track running a track day and get them to noise to test it ;)
  3. scooby
    scooby Elite Member
    1m@90deg 5500rpm for a thou
  4. Slimwilly
    Slimwilly Member
    Does this level sound quiet , or normal or sporty ?
  5. sinewave
    That's quiet.
    UK Tracks are the most stringent of most places.
    On the road noise in general aint an issue unless it's stupid loud or you get pulled for sumat else and they then feel like 'fine tooth combing' U!
  6. Blade runner 1
    Thanks for that Scooby, that makes sense.
  7. scooby
    scooby Elite Member
    not sure what you mean? this is just how they test noise levels at tracks
  8. sinewave
    Funnily enough I'm off to Oulton 2morrrow just for a Noise test prior to a Trackday on the 23rd.
    Had some mods done to the Bike including a De-Cat link pipe so just want to check it passes before the 23rd, otherwise it'll be an expensive day!
  9. Slimwilly
    Slimwilly Member
    Be interested to see how you get on
    Is it a trackday tomorrow ?
  10. scooby
    scooby Elite Member
    i'm there jay
  11. beckylou
    beckylou New Member
    At Castle Combe you need to be under their noise limit (105db) at 3/4 RPM. (about 10k RPM on a blade)
    This rules out stock '08 and '10-on Fireblade and a few list of others.
    I'm not sure which exhausts can get the blade under these limits.
  12. sinewave
    My freshly De-Catted link pipe and Akra can failed at 104db! :eek:
    Custom Akra DB Killer on way! :rolleyes:
