Mechanical rattle at 4000rpm ?
Discussion in 'General 1000RR Discussion' started by And7rp2, Nov 12, 2012.
  1. And7rp2
    And7rp2 Elite Member
    Ok so the blade ( 2010 with about 10k miles ) started to make a rattle at about 4000rpm up to 6000rpm ( wind noise etc makes it harder to hear after 6k )
    Did the usual pulling clutch in etc, checked chain,however the noise alters with revs not road speed! it's still under warranty, so took it stealers the grease monkey takes a look n a listen.
    Seconds later says its the cam chain tensioner !!! Says its about the fifth one he's done in the last 12 months ?
    Well turns out he was right, rattles gone :)
    So just thought I'd let you lot know as I haven't heard that tensioners failed on this model ?
  2. phantom
    phantom Active Member
    honda's like tensioners. replaced three on my bro's cbr600
    and one on my old RR5 blade (10,000 miles).
    only make of bike I have had to change them...nearly as bad as the VFR's rec/reg unit lol :s
  3. 1000rr73
    1000rr73 Active Member
    In warranty or not?
    Ps-glad it's sorted and no I hadn't heard of this on the later blades but then 5 in 12 months is not excessive is it?
  4. Alblade
    Alblade God Like
    How long does it take to replace and any idea of parts cost - think mine needs doing as also noisy.
  5. Si.
    How many miles has yours done Al?? How loud is the rattle?? Thanks.
  6. Alblade
    Alblade God Like
    It's loads Si, about 60k and loud at idle
  7. Si.
    Cheers. Not 100% sure mines tensioner, but it's just on 16k miles and has a slight rattle.. Could be normal though? It's due an oil change and rear tyre, so ill get the guy who does the tyre change to have a look.
    It's under warranty still (2years?) so ill get it looked at before 16th Jan.
  8. phantom
    some tell tail signs is it gets quieter when it warms up.
    last time I done one it was a 40min job and cost me £70
    to buy the part.
  9. Alblade
    Alblade God Like
    Was that on an 08+ blade, don't sound too bad if so.
  10. phantom
  11. Dave V
    Dave V Elite Member
    Looks like mines decided it needs replacing, has all the symptoms. Unfortunately the bikes out of warranty so thinking of doing it myself as running out of time to get it to Arthur before my Euro tour.
    Read up on it and doesn't look like a major job. Only thing that concerns me a little is the requirement to wind and hold the spring in during removal and replacement. Honda do a tool for this, but the cheapest I've seen one is £148!
    Has anyone competed the job themselves on a 08-11 and has solution to winding and holding the spring down? Any other tips would be appreciated. Seen the YouTube vid with the dude his cut down screwdriver, is this the best option in ace of the Honda tool?
    Cheers
  12. Jimbo Vills
    Pretty sure professor dad will have a tool for that dude. Send me the link and ill show him. I'm over the unit for 3 hours killing time whilst Lisa's car gets serviced tomorrow morning. Could do it then if you can get the part?
    Sure dad won't mind taking the glory after we've stripped it and then put it back together ourselves....
    Beer o'clock after lol
  13. martinowen
    When Arthur took mine off he didn't have a tool so he made one quickly, only took him 2 mins so must be easy lol
  14. Dave V
    Dave V Elite Member
    Cheers mate, let me try and get the parts today, although think in most cases it's next day delivery to Honda dealers as they don't stock
  15. arthurbikemad
    It's an easy job just a pain in the ass to get into the mounting bolts, the tools easy to make you just need a bit of tin cut into a small letter T the T slides into the CT and locks the screw in place in a small locating recess in the end of the CT. Think my tool I made costs me about 10p....lol
  16. arthurbikemad
  17. Dave V
    Dave V Elite Member
    Lol, Arthur did tell me that, but that's Arthur making something up not me!
  18. martinowen
    Dave is it the same part as the 05? I have a brand new one still as wasn't the issue in the end.
  19. Dave V
    Dave V Elite Member
    I don't know mate, did read your thread and think MrB said it only for the your bike and even certain years- have you got the part number off the box?
  20. martinowen
    I was shiting myself as he was cutting it with a band saw so close he was basically trimming his finger nails at the same time!
    I swear that blokes got a screw loose!! ;)
