Micron hydratech pipework for RR6 & RR7
Discussion in 'Parts, Accessories & Clothing' started by Evogixer, Dec 17, 2011.
  1. Evogixer
    Evogixer Active Member
    Were £475 new, no longer made. As pictured, £279 + P&P.
    #1 Evogixer, Dec 17, 2011
  2. Nutty Tart
    Nutty Tart Well-Known Member
    That's really lush ... shame I have an 08 ;)
  3. graham1531
    graham1531 Active Member
    do you have to buy a can to match these headers, or would a micron race can fit?
  4. bluekontakt2004
    bluekontakt2004 Active Member
    I imagine with a micron race can this system will be extreemly loud. My 05 is allready really loud with the stock headers with the cats in.
  5. graham1531
    we dont get the same bother with noise up in scotland, there is no noise restrictions at race tracks either, .a few of my mates have growler systems on their bikes, and they are really loud
  6. Evogixer
    As Micron closed down a while ago, new stock is now not available. I bought it for my bike, as if you look at all the power curves of the top race systems out there, this is right at the top. The only reason I went for an Akra evo Ti system, cos my budget changed.
    Micron are certainly not anywhere near the loudest out there, I've had 2 full systems on earlier bikes with no issues at all. A nice deep tone, not offensive at all. Check the spec sheet I included.
    As stated, its a 63.5mm link pipe, any can for this model CBR could be made to fit.
    Seeing as the Akra on my '07 was for an '04/'05 & only req'd a small amount of Dremel work on the fairing, I cant see any reason why this wont fit the earlier bike.
    #6 Evogixer, Dec 17, 2011
  7. CastrolCraig
    CastrolCraig Active Member
    Nice system your selling, and a fair price, but i do have one reservation about your post, i had the top of the range Titanium Serpent header system, large bore, direct from SMR honda, it was the full factory jobbie, and it didnt make as much power as the Arrow Large bore system i replaced it with, also the Akra makes more power, on the same bike, dyno, conditions etc.
    Oh, and on my previous bike, 07 zx10r with serpent header system, it had to have baffles in otherwise it would fail noise tests everywhere.
  8. Evogixer
    Ok, firstly, a large bore works system is intended for a works engine, which is why they wont work as well on a stock or mildly tuned motor(yr Micron being for a BSB motor?) , hence my reference to the Arrow system & why I turned one down...
    Secondly, please do trawl through the endless exhaust data, as I did & then draw a conclusion.
    As far as noise levels go, its there in black & white! OBVIOUSLY IT WOULD VARY, DEPENDING WHAT CAN YOU FIT...
    #8 Evogixer, Dec 17, 2011
  9. bluekontakt2004
    yes and 107db will get you kicked of every single track in the uk unless the run no limits like knockhill.
    the limit is 105db at every track in the uk apart from mallory (no limit) and donington has no limit days.
  10. CastrolCraig
    Large bore for works motors only?
    Strange how they are used on superstock motors like mine then.
    Exhaust Data?
    Dyno results with no variables are the best data
    Oh well, not to argue.
  11. Evogixer
    Superstock...I've seen silly figs on the dyno's at the TT for them, lol! I cant be more upfront with the info provided, it is what it is, end of. Not interested in a debate & appreciate any new member of a forum is under scrutiny to a degree. Being a longstanding member of other bike forums, I will say anything I post is carefully considered & based on fact.
    #11 Evogixer, Dec 17, 2011
  12. Evogixer
    Bumped, I can offer a choice of can, if required(additional cost, obviously)with or without removeable db killer.
    MHP Exhaust
  13. scooby
    scooby Elite Member
    good price that,i'd post it up with a can+price though,might get a better response
  14. martinowen
    Wish I had more cash :(
  15. Andrew
    Andrew Active Member
    I've got the same full setup on my bike and love it!
  16. barry107
    barry107 Active Member
    #16 barry107, Mar 26, 2013
  17. CastrolCraig
    Had this system on my 07 blade that I just sold. 112db with a can, 101 with baffle.
  18. Evogixer
    SOLD. Delete thread pls admin?
