mil light error code- help!
Discussion in 'Maintenance' started by Dougie M, Jul 24, 2013.
  1. Dougie M
    Dougie M Active Member
    Guys
    I'm getting the error code 34 read out from the mil light, this I believe refers to the exhaust flapper which I disconnected and prob turned the wheel to far round.
    I believe if I reconnect this, I can clear the code by shorting the red connector under the seat with some speaker wire??
    Is this possible and if so or not, can anyone advise what I need to do to fix?
    Thanks
  2. dogman
    dogman Member
    turn the wheel manually back to the position it would be if the cable was connected and the flapper closed
  3. Dougie M
    Yup that did it! Cheers :)
  4. Noel
    Noel Active Member
    Hi Dougie, I've got the same error code on my 2014. I've had the standard can off and put it back on. did you get yours sorted?
  5. scooby
    scooby Elite Member
    download a copy of the workshop manual off here,it explains what easc error code is,and also how to reset them (you have the right idea,but theres 4 points on the plug,so you need to know which 2 to bridge together)
  6. Noel
    Noel Active Member
    Thanks scooby I'll have a look
