Motodynamic rear light but with modified rear indicators ideas
Discussion in 'Mods, Upgrades, Accessories and Products' started by Chriscbr, Feb 24, 2015.
  1. Chriscbr
    Chriscbr Active Member
    I have a 2014 cbr and like the idea of the pulsating rear brake light . Incorporating the rear indicators in the light is illegal so i was thinking of ideas to add modified rear indicators or some led strips to the rear foot pegs . Has anyone done this?
    Chris
  2. Si.
    you can buy a resistor box that pulsates the rear light when braking.It goes between the wiring and the rear light, and simple to fit.
  3. Si.
  4. martinowen
    The strobing rear light is illegal also, Infact more so than the indicators
  5. Chriscbr
    Ordered a strobe unit. I think the strobe effect is only illegal if costantly pulses but i am not sure.
  6. martinowen
    Anything that is not a solid light is, I have to remove my motodynamics light for mot
    They would pass if just the indicators but the strobe is like a bad conection so fails
  7. ray
    ray Well-Known Member
    That's a pretty strict tester you've got there Martin.
  8. martinowen
    He's really fair with everything, just the strobing light he won't pass
  9. Chriscbr
  10. Si.
    nope, as i haven't got one mate.
  11. Chriscbr
    Soldered in the strobe unit adding plugs so its a 2min job to put back to standard. The wires are black negative and black yellow brake feed on a 2014 blade. All fits under the pillion seet easily . For a couple of pounds of ebay and a 20mins with a soldering iron its really good.
  12. Gilesy
    Gilesy Elite Member
    My MOT tester is a star. I've the CustomLED rear light and its pulses and has the indicators built in. I don't use the indicator part, but the rear pulsing light gets attention from everyone.. always asking where I got it from. Had cops behind me and they haven't bothered to pull me as yet..
    I also fitted a hidden switch that does this "hazard mode" :)
