New Honda owner
Discussion in 'New Members' started by Ionized_Monster, Feb 26, 2020.
  1. Ionized_Monster
    Ionized_Monster Active Member
    Afternoon all.
    I have just purchased a 2004 CBR1000RR, it's completely standard apart from a power commander, it's been dyno'd with the standard exhaust, will it need to be re-done if i swap it for a aftermarket end can?
    Dave
  2. Boothman
    Boothman Elite Member
    Hi and welcome to the forum - can’t help on the exhaust question but plenty here with lots of knowledge who should be able to answer.
  3. Ionized_Monster
    Thank you
    I've spoken to a friend and he said it should be fine.
  4. raphael
    raphael Elite Member
    Welcome mate,
    I wouldn’t say it has to be mapped with a new can but would Suggest unplugging the power commander if you put a can on as the map in it was as you say, set up for the standard can.
  5. Barstewardsquad
    Welcome. To get the best out of a good new exhaust a remap would help, but it'll probably run fine without it. You may be able to find a map online for the new exhaust when you get one.
    • Agree Agree x 2
  6. BlackDevil
    BlackDevil God Like
    Hi and welcome !
  7. Fwsock
    Fwsock Active Member
    Hi and welcome
  8. bradt
    bradt Elite Member
    Hi and welcome
  9. Blade runner 1
    Blade runner 1 Elite Member
    Hello and welcome, as with any modification that can change the air fuel ratio a remap would be beneficial. It will run with an aftermarket can, but you may notice the odd flat spot and it might not run as smooth through the rpm range as it could. You may be able to find a map on the Dyno jet website with a similar end can and get it close.
  10. LRJimmy
    LRJimmy Active Member
    Hello and welcome
  11. keithg1748
    keithg1748 Active Member
    Hi and welcome
  12. Selmer50mark
    Selmer50mark God Like
    Hello and welcome
  13. Ionized_Monster
    Thank you all for your warm welcome :)
  14. Ionized_Monster
    Thank you for your help, I shall look into it
  15. Ionized_Monster
    Thank you for your help, i shall look into it
  16. mk3golfcab
    mk3golfcab Elite Member
    Hi Dave and welcome! Look forward to seeing pics of your ride :)
  17. PauloHRC
    PauloHRC Moderator
    Hello and welcome!
