Newbie need help.
Discussion in 'Maintenance' started by Nottee, Apr 2, 2020.
  1. Nottee
    Nottee New Member
    Hello. New to this so forgive me if I'm in the wrong place.
    I have a 06 fireblade which is suffering from a leaking fork.
    I'm fairly confident that a can do the job myself.
    But I brought the kit which was for my model and it was come with silkolene rsf 7.5
    Double checked with silkolene and there site recommends 2.5.
    So is the 7.5 wrong and would damage or not work. Or simply a slightly different feel?
    I would appreciate any guidance.
    Thanks
  2. Mr_Chin_LK
    Mr_Chin_LK Well-Known Member
    Welcome to the forum Nottee.
    I've never done any type of fork overhaul, so unfortunately I can't help with your question.
    Chin
  3. Selmer50mark
    Selmer50mark God Like
    Hello and welcome
    According to the manual its 10w fork oil
  4. Boothman
    Boothman Elite Member
    Hi and welcome to the forum
  5. Nottee
    Nottee New Member
    Thanks for your responses silkolene contacted me and said it would do no harm. It would just be a little stiffer.
    So I think I will go with it as I have it.
    Thanks again.
  6. CharlieR85
    CharlieR85 Elite Member
    Hi @Nottee welcome. Oil weight is down to your preference really, the higher the weight the more dampening you will have. If the manual says 10w then 7.5w will be fine. Not sure why silkolene would recommend 2.5w though, that doesn't sound right.
    Here's a really good video for servicing conventional forks....
    And a really good video for servicing USD forks....
  7. CharlieR85
    By the way, in the videos he uses a universal seal driver that can be used on different diameter forks. I have one of these and think it's a bit crap, I'd get the exact size seal driver for your forks.
  8. Black & White
    Black & White Well-Known Member
    I've always got away with a suitable sized socket, as long as the seal is fitted the same height all the way around.
  9. CharlieR85
    A socket won't pass over the fork stanchion.
  10. Black & White
    Silly me.
    I've only done one rebuild & they were traditional RWU forks. I think I tapped the seals in with a hammer on an open ended spanner.
  11. Muffking
    How about a length of plumbing waste pipe that's the right diameter?
  12. Bikeboy
    Bikeboy Active Member
    Wont go over the fork ends.
  13. Bikeboy
    You can use that in rwu forks. But not upside downs
  14. Muffking
    Fair point. How about slicing a groove down it and opening it up to slide over the stanchion?
  15. Bikeboy
    That could work.
  16. bradt
    bradt Elite Member
    Welcome
