Numpty Nomination coming soon but begging for now...
Discussion in 'Wanted' started by thezipsteruk, Jul 4, 2014.
  1. thezipsteruk
    thezipsteruk Elite Member
    Afternoon People Ill let you know what i did later...as I'm bloody fuming with myself at present.
    But
    does anyone know have the rod that connects the gear lever to the selector shaft.
    Im in desperate need, do let me know if you have one up for grabs.
    Im off for a bit to see if a local stealer has one
    thanx
  2. martinowen
    Arthur may be your man mate
  3. Givover
    Have you been fiddling with new Rearsets ?
  4. thezipsteruk
    thanks to you two.
    Ok time to come clean, nothing as good as new rear sets!
    imagine this....
    you get in after a shopping day :( and you need a little unwind, so obviously you go for the cbr, for a quick sneak out for an hour.
    Get your gear on rush out back to take off disc lock, start her up then wheel her backwards out of the bike tent....KERRRCLUNKKKK!! **engine stops**
    WTF!!
    then it dawns on me...some silly twat (me) decided to put another lock on as it was going to be left for a few days.
    I didn't put it through the usual place (pillion pegs)
    It wouldn't reach as the cable was too short so i put it here....duh!
    I know..bloody useless, but I was tired in my defence.
    Well if you forget and wheel it back with lock on you bend the rod, which clunks the gears and stops engine.
    I shit myself as I thought the engine had locked until my stupidity dawned on me.
  5. Stevie_d
    Stevie_d Senior Member
    Jesus Zippy, wtf have you done :confused:
  6. sps170373
    At least it wasn't the disc lock left in the disc, but good numpty nomination though ;)
  7. thezipsteruk
    Luckily I've found my old 97 blade rod which is the same length, just not immaculate.
    at least i can ride again, feel a right pillock..and i never got my ride lol
  8. Stevie_d
    Lucky you never scratched the frame int process !!
  9. thezipsteruk
    good point! ill consider myself lucky too
  10. GappySmeg
    GappySmeg Well-Known Member
    Genius :D
  11. Womblewizard
    Womblewizard Active Member
    Can't help with a new rod, but print this out and stick to the inside of your visor as a reminder!
  12. martinowen
    Also zippy when making a bracket for my heat shield I hacksawed through the rear peg in about 2 mins with a blunt blade! Sawing that off wouldn't stop the bike being ridden either so I would re think that one mate.
    Oh and before I forget WHAT A NUMPTY!
